Any one else getting more than 30 per charge?
Discussion in 'Prime Fuel Economy & EV Range' started by Toyotaisme, May 20, 2017.
  1. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    I used to think that the m/kwh was a good measure until I did my experiment and got 48.2 EV miles on 1 charge with a m/kwh of only 7.2. I have had readings of 6.8 to 7 before but never got much above 37 EV miles.
  2. Richter915
    Richter915 Junior Member
    New York
    Now this intrigues me...what is causing the discrepancy between the mi/kwh and the expected range, the math should line up. I mean, at 7mi/kwh on a full charge should get you at least 43 EV miles.
  3. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    I checked my spreadsheet and my previous post should have read 5.8-6 mi/kwh (I can't edit it). I tracked 42 charges and they were very consistent. So the numbers are within range. Sorry for the confusion and thanks for bringing it to my attention.
    HPrimeAdvanced and joachimz like this.
  4. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    so 48.2 miles at 7.2mi/kWh = ~ 6.7kW ... since the usable capacity for EV is only ~ 6.2 this would indicate that you also used the HV portion of the battery, that is interesting and also in line with my observation (I've come home several times with EV range dropping to zero ~ 0.2-0.4 miles away from home but car stays in EV, going really slow, no more than 25mph and accelerating that even a crippled snail could pass :ROFLMAO:) ... but you also had some range remaining, right?
    #584 joachimz, Jul 23, 2017
  5. joachimz
    451
    612
    17
    SoCal
    yep ... my displayed EV range is consistently 41+
  6. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    Yes, I had .1 left when I took the pic. Sometimes it seems the .1 miles seem to last a long time.
  7. joachimz
    451
    612
    17
    SoCal
    assuming you charged right afterwards, and I don't know whether you have the option to see actual charge in kWh, but the time to charge display in the car - do you recall what the charge took? hrs?
  8. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    Sorry don't know how long it took. I can't see the actual charge, but I used to calculate it by EV miles divided by miles/kwh displayed for the day. After checking 42 charges it was an average of 6.27 kwh per charge.
  9. joachimz
    451
    612
    17
    SoCal
    np, just curiosity ... the data is in the car, just no way to get to it :cry::mad:
    Prius from Dad likes this.
  10. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I'm ashamed :notworthy::notworthy:. Tried to take the same route back from Ann Arbor Michigan. Was in right lane, wanted to go straight through, turns out I was in a right turn lane, oh well I turned right. Went to the next intersection, turned left, followed it to US 23! US 23!!! nooooo!!!!! speed limit's 70 MPH! Damn! went for about five miles because there were no exits for five miles! Finally got back to the rural road that has a 55 MPH speed limit, but the damage has been done. :cry::cry::cry:
  11. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Gosh, Batman, thwarted again by infrastructure protocol!! Alas, all that hard work gone to waste!!
    Fear not, oh persistent one, you have already kicked the Crippled Snail to the wayside with your most stellar performance!! I'm wallowing in 34.6 (read, 35 EV on Entune). I bow to your superior performance and hereby knight you, Master Crippled Snail!
  12. priuscatprimeguy
    2,730
    2,640
    July 23, 2017 35.9 EV miles :cry:
  13. joachimz
    451
    612
    17
    SoCal
    :cry::cry:
    that 70mph hwy ...
  14. Oniki
    Oniki Active Member
    652
    500
    Colorado
    Are you reading off the log ? Other trips the same day may skew the result.
    When my drive to work is my only car use that day I see about 7.5 miles/kWh for my 42 mile drive and a few percent of battery SoC left over if all EV, so it is accurate to within the one decimal place of the display.
    #594 Oniki, Jul 24, 2017
  15. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    I tried to edit that post but couldn't. See post #581
  16. Oniki
    Oniki Active Member
    652
    500
    Colorado
    I'm under the impression that usable battery is ~ 5.68 kWh*, so 7 miles/kwh should give about 39.76miles of range
    *This is calculating backwards from the EPA MPGe, assuming 15% charging losses
    #596 Oniki, Jul 24, 2017
    dalcon95 likes this.
  17. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    The usable portion of the 8.8 kWh battery is about 6.3-6.6 from what I have read here and experienced.
  18. Oniki
    Oniki Active Member
    652
    500
    Colorado
    I don't think that is possible, based on EPA measurements:
    25 miles range
    125 MPGe from the wall
    33,400 Wh per gallon energy equivalent
    So a mile requires 33,400 Wh/125 = 267.2 Wh from the wall
    And 25 miles requires 267.2*25/1000 = 6.68 kWh from the wall
    Your usable battery capacity range could only be correct if charge losses were 0 - 5%
  19. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    I disagree but I will leave that to the experts.
    HPrimeAdvanced likes this.
  20. Tideland Prius
    16,667
    6.3 kWh is what you see on your bill and that includes charging losses. The actual capacity is around 5.5 kWh.
