Any one know the "ceremony" to marry my blue tooth phone w/ my car's blue tooth?
Discussion in 'Gen 2 Prius Audio and Electronics' started by sister_sutherland, Jun 21, 2007.
  1. sister_sutherland
    sister_sutherland New Member
    Hi...well, I'm smarter than the average bear, but I cannot figure out how to get my blackberry pearl phone to "communicate" with my prius's blue tooth. I have scoured my owners manual, but not much help there...anyone out there have the 411 on how to get my hands free to work? I have a 2007 prius, package # 6. Thanks
  2. kdk84
    kdk84 New Member
    113
    Michigan
    <div class='quotetop'>QUOTE(Pete's Mom @ Jun 21 2007, 10:57 PM) [snapback]466172[/snapback]</div>
    I have the same prius package as you and have a Sanyo Katana phone. I simply turned on the bluetooth features on the car and on the phone. I believe this is basically all I had to do. I don't remember exactly but I remember it was quite easy. I believe there may be some settings on your phone you have to play with to make sure you are searching for the car and that you give it permission etc. Everything you need to "play" with is on your phone, same for transferring your contacts. All I had to do on my prius was turn the bluetooth feature on and let it start searching.
    Check your phone's manual rather than the prius manual
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Some phones require you to "pair" them with the Bluetooth hands-free device, which in this case is the Prius. Go through the pairing process with your phone, and when it asks for the number, use the one from the MFD screen. It defaults to something like 1111.
    Tom
  4. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I had the same problem until I put down the Prius manual and picked up my cellphone manual.
  5. Godiva
    Godiva AmeriKan Citizen
    10,339
    "Dearly beloved. We are gathered here today to join together this phone and this car......"
  6. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I think it's illegal in most states to marry two blue tooths (blue teeth?)
  7. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Ancient thread, but good point, Michgal. :)
