Any reason NOT to do a Gen4 engine swap if there's an engine issue?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kromis, May 18, 2023.
  1. Kromis
    Kromis Junior Member
    Rosemead
    2014 Prius Plug-in
    Howdy
    Apologies if this is an old topic but I'm relatively new to the forum and Prius/car maintenance in general.
    I bought a 2014 Prius Plug-In with 136K miles from a used car dealership back in 2021 and barely put 2K miles on it since I got it (I know, big mistake and my fault for not being diligent enough and doing more research on the purchase but I bought it with the Replace Your Ride program in California). Recently, I got some "chocolate milk" coming out of my engine after my last oil change which I'm automatically suspecting as a head gasket issue. The local mechanic that did the oil change said the short block might need to be replaced and quoted me $3K for parts and labor :sick:
    If I was thinking that if I were to pay $3K to fix a part of the engine, I'd rather just get a "new" engine. My plan was to go to Hybrid Pit in SoCal to get a rebuilt engine. After reading about the Gen4 swaps here, I'm wondering if there's any reason NOT to get a Gen4 engine if I have the opportunity to replace my engine. So far, I understand Hybrid Pit puts a lot of TLC into their rebuilt engines so I know I'm getting a quality product at least. With an imported Gen4 engine, I'm taking a bit of a gamble with any quirks it might come with. Am I missing anything else? I read that I could source an engine from car-part but otherwise I'm unfamiliar with how and where to source an engine. I'm located in SoCal/SGV.
    Plans for the car:
    • I would like to drive this for at least another ten years
    • I don't plan on buying an EV in the near future
      • Looking at Project Lithium in case I do need to replace my battery and hopefully get more electric range if the tech keeps advancing
    • Because I bought it through the Replace Your Ride program, I need to keep the car for at least 30 months (30 months is in March 2024) otherwise I would have to pay a prorated amount back to the program if I were to relinquish it earlier.
    Some additional details about the car:
    • Only 1 previous owner
      • Based on car service history, owner kept up with scheduled maintenance
        • EGR was cleaned in May 2020
    • Service note from May 2020
    • Issues leading up to "chocolate milk" issue
      • I was able to drive it just fine with no significant coolant loss and no cloudy oil until one day the check engine light was flashing while I was driving on the freeway. The engine shook a bit and then it strangely went away as well as the flashing check engine light. However, I noticed that whenever I slowed down a bit (like say below 40 mph) or rev'd lower, then the shaking would come back until I went above 40 mph. After this event, the engine shook every time the engine turned on and eventually the check engine came back on.
      • The check engine turned out to be a P0301, just like last owner encountered before he gave up on the car the next month. I swapped the ignition coils on cylinder 1 and 3 but I still got a misfire on cylinder 1 for some reason. I did the same with spark plugs 1 and 3 (after putting the coils back) with no change. After swapping out all four spark plugs with new OEM ones, the engine stopped shaking and the check engine light eventually went away.
      • This didn't last too long as I started noticing the oil get more and more milky later on; it didn't seem too bad actually until I got an oil change and saw that a LOT of the oil that came out was basically milkshake :sick: So now I've only been using it on very short trips on battery only as to avoid turning on the engine (plug-in part of the Prius coming in clutch :cool:)
    • Diagnostics
      • I did a block engine test and it came out fine (just a tiny bit of green)
      • Have not done a compression/leak down test or gotten a second opinion.
        • I'm not sure I want to take my car to the used car dealership (about 13 miles away from me) to get a second opinion because I didn't really want to deal with towing if there's a chance that I would need to get engine work done. Also I'm not sure how much it costs to have my car inspected to get that second opinion.
    Thanks for reading
    #1 Kromis, May 18, 2023
  2. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Well the Gen 4 is turning out to have similar problems as the Gen 3 original engine is having because it's not individual parts on the engine that's causing the problem It's the open deck design that is the ZZ engine similar to the Camry's a engine I think Open deck You see them failed all over the country albeit hi mileage when this happens near 200k it's hard to blame the manufacturer at this point I mean what are we trying to say ice engines are supposed to last until 500,000 miles? I don't personally think so I was getting $300,000 miles on 2TC hemi-head Corolla engines back in the '70s. I didn't think going forward things were going to go sky high as in mileage I knew engines would become weaker as we tried to save weight combine the functions etc etc here comes the open deck design makes decent mileage lighter weight modular easier to assemble etc but it is inherently a week or design The Gen 4 is the same engine with some sleeves and some add-on pieces to fix the inherent problems apparently it hasn't done such and probably not going to get fixed the ZZ engine will be on the way out the next go round I'm pretty sure we'll be moving to a 2 l something else etc so if I would do anything I would buy a low mileage takeout from the Japan domestic market not fool around with somebody in America who claims they can do good work and build wonderful engines out of the open deck inherent weak design that we're dealing with that even sounds silly to me but they're where they need to be in California so good on them no matter what you do to a weak design you're probably not going to reengineer it and do a whole lot better with it for Christ's sake you're original made almost 200k back in the day before the internet you'd have been jumping up in the air screaming oh what a feeling right?.
  3. Mendel Leisk
    42,369
    Typically that’s due to head gasket failure between cylinders one and two. Leak down test or boroscope inspection can confirm. Sounds like it let go in 2020.
    What’s oil consumption like?
    Paladain55 likes this.
  4. ChapmanF
    19,053
    I have read a disconcerting number of stories here that start wit Gen 4 into Gen 3 transplants and end with overheating problems that never get solved or convincingly explained (they sort of trail off into a bunch of gobbledygook about cutting jiggle pins out of thermostats or trying yet one more time to get suspected "air lock" out of the system).
    It can leave one with kind of an uneasy sense that no one has figured out what they're doing yet with that transplant.
  5. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Nothing wrong with a gen 3 motor. Keep it simple and swap in a gen 3 unless you enjoy pain or figuring out problems. There's nothing wrong with these motors if you make sure the EGR system is kept clean so it isn't misfiring 24/7 (they typically don't throw a cel light for misfire until it hits an extremely high knock level). Also, change the oil every 5k, don't be cheap.
  6. Kromis
    Rosemead
    2014 Prius Plug-in
    I get that I'm sort of stuck in a "putting lipstick on a pig" situation with the Gen3 engine but wasn't sure how much better the Gen4 was supposed to be. I just want another 100K miles on a "new" engine with the revised pistons and better head gasket. Hell, I would LOVE to just ride out this Prius for as long as possible but haven't looked if anyone has taken the Gen3/4 to that extreme mileage yet (300K+). I suppose getting JDM Gen3 engine with 50-60K miles might be fine for my 100K miles target.
    Damn. :(
    I think the oil consumption was fine; I never needed to add more oil since I brought it home from the dealership (I didn't have any 0W-20 on hand anyway until I bought some for the oil change). Then again, I barely added 2K miles to it with a lot of those miles (maybe half even) being pure electric.
    I've been afraid to engage the engine ever since that last oil change. There have been times here and there where I accidentally accelerate too fast and cause the engine to turn on; when it does, I check the oil after I get home and I see the oil is not completely clear but not completely opaque like milkshake either. I thought this was just condensation since I rarely turn on the engine and why I kept driving it after I "fixed" the shaking until it was time to get an oil change where it turned out more of that oil was opaque than what the dipstick showed me. I think I might actually just go to the used car dealership to get it checked out for a second opinion then and just run the engine there and back. I'm sure it wouldn't be too bad and then I can check how bad the oil gets after a longer session on the road.
    Overheating? Really? Interesting. I thought the only issue would've been having to reuse the Gen3 EGR and needing to clean it out every so often. If it's not the water pump causing the overheating then that definitely sounds like a potential headache in the future. I'll need to ask Hybrid Pit some questions about this.
    I do like figuring out problems...as long as they don't cost me an arm and a leg! :whistle: I sort of view the car like a computer where I'm choosing the parts and learning how to troubleshoot it as I'm making it my own. I do enjoy the satisfaction of making something "mine" in that way. But I'm also lazy and would like less headaches down the road~ :cautious:
    Good to know about the CEL not showing up until something bad happens. I really hope it's not a clogged EGR as I can't imagine it clogging up after 2K miles from the last time it was cleaned. I did read that it's better to change the oil at 5K miles so I'll stick to that. Just want oil prices to come down a bit more :D
  7. ChapmanF
    19,053
    Yeah, it's not the water pump. There are a few differences in how the engine is plumbed into the car between Gen 3 and Gen 4, and people have improvised how they'll make the ends join up when they put the 4 engine in the 3 car, and there are at least two "do it like this" diagrams floating around here, one of which is clearly goofed up and one of which at least looks kind of plausible on its face. But thread after thread after thread with 4-into-3 transplants end up as stories of persistent, unresolvable overheating. (It doesn't help that usually people don't mention which "do it like this" diagram they were following.) Then the threads trail off into "well somebody said somewhere I should cut the jiggle pin off the thermostat" and "must be airlocked, try 20 more times to burp it" and those are usually the last things heard on the thread.
    gggGary and Kromis like this.
  8. bisco
    52,891
    hybrid pit has a good reputation with rebuilding gen3 motors
  9. Tombukt2
    13,875
    2,521
    Durham NC
    I had like 265 or something like that on the persona when the two z engine went out and I just got a JDM spec 2Z engine Gen 3 and plopped it back in the car and I also got a transmission at the same time from the same supplier so the engine and transmission would have similar mileage so maybe my MGs and all that would be up to snuff The transmission in my original car was of no problem and it's sitting here in the shop worked fine but with near 300K on it I figured for the $150 they charged me extra to get a transmission with the engine I said what the heck And now I've almost put 50,000 on that JDM engine that I put in the car so that's pushing me right up around 300,000 on the chassis the original engine the center girdle is broken it's sitting here in my shop's yard never to be messed with again to me I believe for some reason the JDM specification engines maybe are built with more pride because they're going to be staying in there Asian countries I don't know personally but it would seem to me just like Ford SVO keeps the good crap for I would imagine American roads you know and the fancy engines mostly on american roads. Anyways just a fleeting thought Plus our good stuff couldn't really go to a lot of foreign countries they couldn't even get through mileage trials or whatever I mean a Ford mustang going to Italy would be the gas guzzler from you know where in that country It would never fly or I guess it would.
  10. Paladain55
    414
    172
    The South
    If you have chocolate milk, and a cylinder 1 misfire its a head gasket leak on cylinder 1 at the minimum. Thats the cylinder that gets eaten first by egr clogging. You got got. But not the end of the world. These cars are pretty tough bottom end wise. I would just do a head gasket kit and an engine swap price comparison and see what you think. Spend the time to go to one of the guys who do head gaskets on priuses a lot.
  11. chaddarack
    chaddarack Junior Member
    29
    Georgia
    I have a Gen4 motor in my Gen3. Yeah it had overheating problems for a minute. I tried putting my old Gen3 water pump into the Gen4 motor and it turns out they aren't a good swap even though the core motor is supposed to be the same. I put the Gen4 pump in there and kept monitoring my temps with my OBD app and its been running great. I currently have 312k miles. Swapped the motor at 262 miles. Had to replace brake booster too, which sucked on price. Got my Greenbean battery warranty swap for free last month. Good to go for another 50k it seems. My oil is staying clean and not consuming any. "FixatPrius!"
