Any suggestions if you lose your remote?
Discussion in 'Prius v Main Forum' started by cucaio90, Feb 4, 2016.
  1. cucaio90
    cucaio90 Junior Member
    48
    debary ,fl.
    2015 Prius v wagon
    Every keyless entry owner nightmare:what are you going to do if you lose your remote and you're 300 miles away from home,and your second remote is home.One of my solution is to keep the spare key in a magnet container under the car,the second remote in the car hidden, with the battery taken out,any other suggestions?
    bisco and beachgeek like this.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,490
    6,576
    Texas Hill Country
    Other than your idea, be able to have another one made at a dealer. Just like most other cars today, even those with keys (which usually have transponders in them), you pretty much have to go to a dealer and have one made. Even then you need to have the keycode number that came on a metal tag to have them program a new one. I emailed that code to myself so that I could access it later. Expensive.solution (going to the dealer) but possible. Best thing? Don't lose your keys.
  3. cucaio90
    48
    debary ,fl.
    2015 Prius v wagon
    I know the easy way is not to lose your keys but everybody knows Murphy's Law.
  4. mikefocke
    4,039
    1,835
    Sanford, NC
    When we travel together, wife takes one, I the other. Reduces chances they are both in the same place. I've lost the mag holders before.
  5. bisco
    52,372
    we do the same. ^^^ even if i'm alone, i bring the second and leave it in my hotel safe, or wherever i'm staying.
  6. ETC(SS)
    7,348
    2 Choices:
    1. Buy a used fob and try to find a locksmith to reprogram it for a reasonable fee.
    2. Throw yourself on the tender mercies of your local dealer.
    Good Luck!
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I think there is a much higher chance of losing both keys while on travel. Leaving one key at home is the backup plan. If I lose my key on travel, the one at home can easily be mailed by a family member. I try never to keep both keys together except when at home.
  8. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I would remove the battery from the second remote, place both inside plastic zip lock bag or bags, and hide them inside the car where someone who breaks a window to get in will not find it. There are dozens of places to do this. For example, I would pull off a snap-on dash or rear panel and hide the key behind one of those. Unless you forget where you put it, nobody else will find it.
