Any suggestions on this
Discussion in 'Gen 3 Prius Accessories and Modifications' started by kaushikchand, Jul 1, 2019.
  1. kaushikchand
    kaushikchand New Member
    labasa
    i-Tech
    52,638
    sounds like you need a new brake actuator, how many km on her?
  3. Hjeff
    Hjeff Junior Member
    25
    On my daughter's 2011, and her friend's 2010, Toyota replaced the master cylinder for free. Over 150,000 miles (240,000 km)
    Symptoms:
    Odd braking
    No regen braking
    Tons of warning lights
    The hydraulic pump (actuator?) that lightly bzz/hmm as you approach the car --it pressurizes the brake assist --It should only run once in awhile. If your'e leaking fluid (but not losing it on the reservoir) it has to run every 5-10 seconds.
    At first they said it would cost about $2000. Later they called back and said they found a notification & it was free.
