Any test for Brake Pedal Stroke Sensor?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by turbo5spd-prius, Mar 1, 2025.
  1. turbo5spd-prius
    turbo5spd-prius Junior Member
    71
    United States
    Is there a way to test the brake pedal stroke sensor? I.e. a way to test it outside the car. My original one gave problems. I tried a used one from E Bay and it does the same, though mine's smooth and the used one is detented.
  2. Tombukt2
    Tombukt2 Senior Member
    13,785
    2,497
    Durham NC
    This is the piece that's actually connected to the pedal? I don't think detented is correct but I'm not positive of that but I would think so If this is the piece that's connected to the pedal it feeds the pressure back to the actuator which is an almost the middle of the car on the firewall it's like the brake master cylinder on the older Corolla.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    What are your symptoms? Any trouble codes?
    From the test descriptions, the sensor has a V-reference power supply, ground, and dual outputs that change voltage.
    It could be a simple variable resistance sensor, or it could be variable output hall effect sensor.
  4. turbo5spd-prius
    71
    United States
    Yep, it's connected to the pedal with the spring loaded arm. I say "detented" for the used one because it's not smooth when you move that arm but you can feel it "tick" lightly through its arc.
  5. turbo5spd-prius
    71
    United States
    I get the ((!)) light on the dash and the code that indicates a brake pedal stroke sensor fault (don't remember the code). It seems to only affect the braking phase near the end as the car comes to a stop. You can feel the brakes sort of grab and let go quickly. Since it's almost stopped, the feeling isn't strong and it's really more the sound you notice. If you're not listening for it, you won't ever notice.
  6. Tombukt2
    13,785
    2,497
    Durham NC
    No I remember this very well when my break actuator was failing I replaced it all that went away as far as I know the stroke sensor or the part that's connected to the pedal it doesn't have any electronics does it isn't it all just hydraulic I don't have one out to put in my hand so if that's the case then it's measuring the stroke or the push of the brake fluid inside of the actuator because when you step on this thing connected to your pedal it pushes fluid over to the actuator I do believe and then pretty much the computer takes over so if you push on the pedal and it doesn't move the amount of fluid expected or something along those lines I guess you would get a code for the stroke business I guess. If you have this out in your hand doesn't this look kind of like a regular master cylinder from a Corolla or a Yaris no electrical plugs it's hydraulic fittings and where the fitting connects to the pedal that pushes on the hydraulics that should be rebuildable It might even be stamped on the side of it 7/8 or 3/4 some metric equivalent That's the bore size of the hydraulic piece that goes up and down in that hole It's kind of like the inside of a rear wheel cylinder. I would think you'd want that thing to be operating smoothly and moving a good shot of fluid every time you compress it If not pull the boot remove the snap ring or the wound ring pull the guts out and have a look If it's 3/4 or 7/8 bore there should be all kinds of options for the rubber parts
  7. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    Reporting the code, rather than than text, is important.
    People using an inadequate scan tool (read cheap, limited) often report P1121 as "Accelerator Pedal Position Sensor Error, Performance/Range". On another car, even a Toyota P1121 might mean that, but on a Pruis it does not. It means that the coolant flow control valve position sensor circuit is stuck.
    It might be in your best interests to remember that code or do a rescan.
    MAX2 likes this.
  8. turbo5spd-prius
    71
    United States
    Here is the sensor.
    I'll rescan tomorrow but looking at my old generic system screenshots, I'm sure the error code is C1207. I use techstream.
  9. dolj
    dolj Senior Member
    8,633
    4,385
    C1207 is not found in the 2006 manual.
  10. turbo5spd-prius
    71
    United States
    Sorry, C1247.
    My laptop keyboard is wonky so I mistyped it.
  11. turbo5spd-prius
    71
    United States
  12. Tombukt2
    13,785
    2,497
    Durham NC
    Never seen that part out of the car look at the slotted holes that hold it on like an old automatic choke cover on a carburetor or a throttle position sensor so it's adjustable and it can bring it in earlier later or something so with that switch there I would think that would be able to set a code for that switch and that's mounted on the hydraulic thing but the pedal connects to cool. I wonder what the mounting procedure and setting up the switches I guess that's what they're talking about from the manual there where they're bringing on different voltages.
  13. turbo5spd-prius
    71
    United States
    Yeah, it's on the brake pedal subassembly and really annoying to reach, especially if you're tall/big framed. It's adjustable like you say but you need a live scanner or techstream. I adjusted it but the error doesn't go away. Ditto with my original sensor. Strangely, when the error popped up originally, I adjusted it so the error went away but after some months it came back with no adjustments being helpful anymore.
  14. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    I have provided in #10 the address of the link to the manual for this error.
  15. Tombukt2
    13,785
    2,497
    Durham NC
    I have the Toyota software I'm not sure about making the adjustment if this happens to my car I'll make sure I take my stroke sensor complete with the sensor and the hydraulic piece and everything all together and not mess up the adjustment I guess it's the trick.
  16. Tombukt2
    13,785
    2,497
    Durham NC
    Then you can see by looking at the manual the code and the subcode you have tells you you know whatever the stroke sensors not doing so if the light was on and the brake pedal was working okay I probably would opt out of getting in any hurry to trying to just that stupid thing.
  17. turbo5spd-prius
    71
    United States
