Any warranties still in effect for a Prius 2010 (Canada)?
Discussion in 'Gen 3 Prius Main Forum' started by Briant1840, Oct 18, 2017.
  1. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    Have we ever heard of a Canadian Prii needing a new HV batt yet?
  2. Prodigyplace
    12,554
    11,773
    Central Virginia
    @Tideland Prius and @Mendel Leisk are our Canadian archivists.
  3. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    I apologize for being the last one to understand this, but I wanted to get clarification about the extended EGR warranty.
    If I'm in the US, is my '14's EGR covered against carbon build up until '24?
    amos likes this.
  4. Tideland Prius
    16,555
    Does our 2005 count? although we traded it in for a 2016 Prius instead.
    Prodigyplace likes this.
  5. amos
    amos Active Member
    371
    282
    los angeles
    It should be covered under warranty. Cause its a part of the emission. But its also written there that a failure code is needes. Well next saturday im going to dealer here in l.a and i have no check engine nor code. I think i can get them to do it for free.
    MelonPrius likes this.
  6. Mendel Leisk
    41,412
    A couple of thoughts:
    1. (and sorry for getting chauvinist, protectionist) The initial premise of this thread was Canadian Warranty. That said, it's a small world, and a lot of 3rd gen Prius in the States are going to be getting this.
    I'm not sure: IS there a US Warranty Extension on the EGR? I did a half-hearted search, didn't find anything. Which is surprising, with the Inverter recall the US got a Warranty Extension, IIRC it never happened in Canada?
    2. Going into a US dealership, citing a Canadian Warranty Extension, one that mentions symptoms/codes, I think you're going to find it less than smooth sailing.
    And: be careful what you wish for. This is a tough but doable DIY, somewhat time consuming and painstaking, that can be done with no outlay for parts, even gaskets if you're careful. Just a few "shop supplies". But it takes time and effort, which are commodities in short supply for rushed dealership mechanics.
    #26 Mendel Leisk, Oct 22, 2017
    MelonPrius and Prodigyplace like this.
  7. wjtracy
    11,367
    3,608
    Northern VA (NoVA)
    Sure...why not? Stand up and be counted!
    pilotgrrl and Prodigyplace like this.
  8. MelonPrius
    839
    516
    Nevada
    Amos, I see you're in LA. Did you receive a letter for an EGR extended warranty for 10 years?
  9. amos
    amos Active Member
    371
    282
    los angeles
    Nothing from dealer . But i took it that @Mendel Leisk document posted for a canada warranty will hold over here too cause we have the most stricted emission requirements here. I will try to find time and go to culver city toyota this coming saturday. Which dealer is closer to you.
  10. MelonPrius
    839
    516
    Nevada
    Amos, I’m hoping you find good news for us. But I’m not getting hopes up unless there are forum members who actually received this letter in the US.
    On an unrelated note, did Canada and other countries receive the IPM extension that we received in the US?
  11. Mendel Leisk
    41,412
    Per my post #26, I believe no. We did get the inverter software update, but no warranty extension.
  12. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    We got the IPM extension. Unless I was dreaming about it. I don't usually dream about car stuff. ;) I think I posted it.
  13. amos
    amos Active Member
    371
    282
    los angeles
    My fellow prius owners.
    My car is at the dealer now for the egr cooler issues.
    Here is what i got from them.
    Replacing egr cooler including egr valve.all for free replaced under emission warranty.
    The emission warranty in cali is 150k miles/10 yrs. So i was told by dealer.
    IM and throttle body clean Not covered under warranty cause not a part of the emission. Dealer wants $300 for the clean job of those two items. I declined..
    I just want to thank @Mendel Leisk for all that documentation posted bout that warranty repair.
    #33 amos, Oct 28, 2017
  14. MelonPrius
    839
    516
    Nevada
    Thanks for reporting. Information, like this, is the best part of this forum. Since I'm in a non CARB state, I'll assume that my warranty is 8/100k, until I hear otherwise.
