Any way to edit the phonebook once its transferred?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Kev1000000, Aug 2, 2004.
  1. Kev1000000
    Kev1000000 New Member
    271
    Livonia, MI
    I need to switch a few numbers and change a few things, can i do it via the MFD or do i have to make the changes on the phone and re-transfer the whole thing?
    For some people, i have both cell phone and house numbers stored on my phone, but the prius only uses the house number and for some people, i only want it to use the cell number...
    Any suggestions?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    99.9% sure it can only be done on the phone and retransfered.
  3. Eisenson
    Eisenson New Member
    142
    I tried a few things, including accessing the utility Bluetooth screen, but no-go.
    Unfortunately, you must do the editing on the phone, with separate entries for
    John K Office
    John K Home
    John K Cell
    etc.
    fyi, there's someone working on a patch for that but I worry that a hack will create more problems than it solves.
  4. glscheil1
    glscheil1 New Member
    150
    Raytown, MO.
    Phonebook errors
    When I installed my phonebook, I accidentally did it 2 times so I had 2 entries for every person. It wasn't too dificule to delete the 2nd set.
    You have to press "Delete" and THEN HIGHLIGHT THE NAME AND NUMBER to be deleted.
    Sounds backwards but that's the way to do it.It will also ask you if you are sure you want to delete the entry.
