Any way to figure out what models have a certain radio?
Discussion in 'Prius v Audio and Electronics' started by Slide_into_the_V, Jun 27, 2022.
  1. Slide_into_the_V
    Slide_into_the_V Junior Member
    phoenix, az
    2013 Prius v wagon
    So, I had a radio shade produced, it fits the 57011 radio. I'm trying to figure out which models come with this radio, as most radios are flat, and this one has a bit of a curve, so the shade only fits this specific radio.
    any help is appreciated
  2. ChapmanF
    18,249
    Have you tried looking up that radio on parts.toyota.com, then expanding What This Fits?
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,166
    6,319
    Texas Hill Country
    2012-14 Prius v trim 3 and some trim 5s that did not have the upgraded jbl system. Probably fits the 57010 unit used in trim 2.
    $14.99? How does it stay attached?
  4. Air_Boss
    Air_Boss Senior Member
    4,200
    1,184
    New Yawk
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,468
    2,435
    Taylors, SC
    Your profile states that you have a Model l Prius v. This model does not exist. Only models two, three and five were made in 2013.
    The base model two has the basic radio without navigation. Models three and five have the upgraded radio.
  6. Slide_into_the_V
    phoenix, az
    2013 Prius v wagon
    Great suggestion, I'm going to do that right after writing this reply. (edit: found it- it only goes in the v, 2012-2014. Hard to tell if other radios have the exact same exterior, but with different features. The technical drawings don't really show curvature of the radio)
    It uses double sided mounting tape. I've recently upgraded the tape- the old stuff wasn't quite good enough.
    You can get it here for now-
    https://www.ebay.com/itm/304512560036
    I will have inventory on Amazon in a few weeks.
    You are correct, I has the dumb. Also, I has a model III.
    #6 Slide_into_the_V, Jul 7, 2022
    Air_Boss likes this.
  7. ChapmanF
    18,249
    Maybe you could expand the search to see what other radios can go in those same years of v, as they probably have to match the same surrounding trim and therefore have the same curvature, and expand the What This Fits for those. Maybe also look at What This Fits for the trim panel that goes around it.
    Slide_into_the_V likes this.
  8. Slide_into_the_V
    phoenix, az
    2013 Prius v wagon
    Turns out it's a very narrow range of vehicles- basically 2012-2014 V. Also, hooo dog, the navigation system is $4k on their site. as bad as the actual navigation system is, they'd have to pay me to use it.
    The radio's fine, just not... $4k fine. ha.
    Anywhoo, the radio shade is live on amazon now. I have about a hundred of these, and given the narrow range of cars that this officially fits, that should be more than enough.
