Any way to get EV Auto to stick after power cycle?
Discussion in 'Prime Technical Discussion' started by EspressoFueled, Feb 6, 2017.
  1. scm2000
    scm2000 Active Member
    164
    125
    Ok so when i drive in EV Auto mode, it behaves exactly as EV mode.. it uses up all ev miles before it switches to hv mode and turns on the ICE.
    So for me its just fine to default to EV mode....
    51,897
    that's odd, unless your route just happens to be one that the car thinks is fine for ev. does it warm up the engine when you switch to ev auto?
  3. scm2000
    164
    125
    Not that I can tell.
    Will experiment with it tomorrow.... but it's hard to miss the ICE coming on...
    As far as not switching on the ICE during EV auto driving... I don't put a high demand on it... keeping acceleration within the blue band, sometimes less. I might just spend some gas and try stomping on it in EV auto mode and see what happens.
  4. scm2000
    164
    125
    I just checked the manual on EV Auto mode conditions where the ICE will come on... It's the way I drive I guess. I have it set to ECO mode... I don't drive over 55 on my daily route... Wont have it up to 65 till a trip for labor day... wont have it up to 70 till a trip to DC...
    I don't press firmly on the accelerator or ask for high acceleration.
    The battery has been neither too hot or cold.
    The only time I used the defogger was in plain EV mode.
    I've mainly been driving in EV mode, and experimented with EV Auto mode... so I may no have been on routes that needed the ICE.. like climbing a hill while accelerating.. what I did there was change my route to avoid the hill anyways...
  5. scm2000
    164
    125
    ok just tried very hard in EVAuto mode to get the ICE to turn on. no it is just like EV mode.
    So a problem with my car or something new in the programing
  6. bisco
    51,897
    huh, i'll be interested to hear other owners experiences.
  7. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    I only tried EV Auto once, and I got so much worse gas mileage that day that I haven't even thought about it again and instead switch manually between EV and HV at appropriate parts of my commute.
    The only reason i can think of that I got worse gas mileage is that I used EV in the fastest part of my commute, so that cut my total electric range too much. I never really felt any acceleration differences anyway, so EV Auto just doesn't work for me.
  8. scm2000
    164
    125
    I just don't see a difference between EV and EV Auto. The car behaves the same way... It uses up the EV miles then switches to HV mode. I have never seen it switch between EV and HV while in EV Auto.
  9. CharlesH
    2,796
    1,163
    Roseville, CA
    EV-Auto is supposed to be like EV mode on the Gen I PiP: Primarily EV, but if you step on the gas hard enough, it is supposed to engage the ICE.
  10. scm2000
    164
    125
    In ev auto from a stop i put the accelerator to the floor rapidly and it didnt use the ice
  11. bisco
    51,897
    so there is no discernible difference between ev and ev auto?
  12. zorrobyte
    zorrobyte New Member
    Indiana
    2019 Prius Prime
    Sounds cool. I'll probe the CAN bus and find the packet that enables the EV Auto function and write a little patch to enable it with Openpilot. Should be an easy first hack for me to tackle.
  13. bisco
    51,897
    agreed, should be a no brainer
    please keep us posted
  14. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Old thread, but my PRIME started in HV almost every morning for winter months. TOO COLD to start on EV even if charged full. It is almost like EV Auto isn't it??? lol:LOL:
