Any way to transfer contacts from iPhone?
Discussion in 'Gen 2 Prius Audio and Electronics' started by scott.in.colorado, Feb 8, 2013.
  1. scott.in.colorado
    scott.in.colorado Junior Member
    Any way to transfer contacts from my iPhone into the Prius? I looked briefly and it did not seem so.
    Thanks.
    Scott
    Scott
  2. Jghake
    Jghake Junior Member
    71
    Washington, USA
    I just tried to do this last night. The iPhone bluetooth stack does not support it. I found an application for a Mac that advertised it would work and couldn't get it to pair correctly. I also tried to do it with my Win7 laptop unsucessfully.
    I ended up pulling my contacts off, using BitPim to put them on an old LG dare, then paired the Dare. Once the Dare was paired I transfered the contacts to the car. All in all it would have been better for me to just enter the contacts manually.....
  3. scott.in.colorado
    Thanks, I have found other posts on this since then, and 'no way'.. too bad..
  4. xPETEx
    xPETEx Junior Member
    76
    Victoria, BC, Canada
    2013 Prius v wagon
    On my 2013 paired by bluetooth to my iPhone when I push contacts it just pulls them all from the phone. I wonder why it doesn't do it on the Gen II?
  5. Jghake
    71
    Washington, USA
    I think it has to do with in the newer car, when you press contacts it asks the phone for the contacts where in the gen 2 you have to tell the phone to export it. I rented a 13 and it worked really well but I had the damnedest time getting the 09 to work.
  6. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  7. sameluolity
    sameluolity New Member
    2012 Aqua
    You must be connected to a Wi-Fi network on both your old iPhone and on your Prius device.
    You can use the device switch app to transfer contacts, pictures, and other personal data from your iPhone to Prius.
  8. jasdaller
    jasdaller New Member
    Hong Kong
    2013 Chevy Volt
    For iPhone or ipad users, if you want to transfer data out of your devices, you can use direct data transfer tool, itunes doesn’t allow us to transfer the data directly.
  9. jasdaller
    Hong Kong
    2013 Chevy Volt
    Hope it helps. Transfer contacts from iphone.
    #9 jasdaller, Jun 18, 2017
  10. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    The OP asked how to transfer contacts from iPhone to the Prius, this not really a solution, is it? Unless you've tested a method to transfer to a Prius?
