Any way to turn off speedometer?
Discussion in 'Gen 4 Prius Main Forum' started by littlebird002, Nov 5, 2017.
  1. littlebird002
    littlebird002 Junior Member
    37
    CA
    During normal drive, I pretty much follow the traffic.
    It seems the speedometer is useless and distractive.
    I am wondering is there any way to only turn off speedometer, but leave the shift lever indicator on?
    Thank you.
    #1 littlebird002, Nov 5, 2017
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Not sure on the Gen4, but the Gen2 has a dimming switch on the dash just left of the steering wheel that can dim or turn off the display.
    Pretty sure you would have something similar, but look in the user manual if all else fails.
    goldfinger likes this.
  3. littlebird002
    37
    CA
    You are right.
    There is a dimming switch, but it applies to all lights on dashboard.
    I just want to turn off the speedometer, and leave the shift lever indicator lights on.
    I will whether there is a way to only turn off speedometer.
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Probably not. Either just dim the entire dashboard or just don't look down at it when driving in traffic. The other screens are just as distracting.
  5. littlebird002
    37
    CA
    The only concern is I want to see the shift lever indicator, sometimes it could prevent accident.
    I will try, if no way to leave the shift lever light on, I may just turn off all the dashboard.
    I use smartphone to navigate, but there also Prius dashboard,Prius Entune screen, it is too much light for me :)
  6. Mendel Leisk
    42,191
    I'm speechless.
  7. Prodigyplace
    12,708
    11,847
    Central Virginia
    It is also a legal requirement for you to drive it on public roads. You should either get used to it or get off the public roads so you are not endangering others.
    kithmo, WilDavis, pilotgrrl and 2 others like this.
  8. bisco
    52,693
    the speedometer is distracting? i have a hard time looking for it when paying attention to the road.
    being able to see the shift gear can help avoid an accident?o_O
    kithmo likes this.
  9. fuzzy1
    10,672
    I'll take OP's 'Location:' field as a clue.
  10. Mendel Leisk
    42,191
    Our location has a similar mindset. :(
    pilotgrrl likes this.
  11. Prodigyplace
    12,708
    11,847
    Central Virginia
    CA is the country code for Canada, correct? AFAIK, speedometers are required there too.
  12. fuzzy1
    10,672
    I've noticed that too, but not to the same degree as certain select license plates from my own country.
    I take it as a U.S. postal code.
    The U.S. state and Canadian province postal codes have no overlap. This appears to be intentional, so that when the U.S. eventually annexes Canada, they won't have to change address or phone numbers. Though under the current political climate, it seems more likely that Canada could pick up some seceding U.S. states.
    #12 fuzzy1, Nov 5, 2017
  13. Mendel Leisk
    42,191
    Yeah I think CA equals Californee, the place you outa be.
    kithmo, jerrymildred, bisco and 3 others like this.
  14. Mendel Leisk
    42,191
    This may be a false memory, but I seem to recall one time when we had a "check hybrid system" warning, it replaced the speedometer, so basically the OP's desired condition. I drove to the dealership thus, no speedo, and to quote Little Richards: "I felt like Aunt Jemima without her pancakes".
    kithmo and RCO like this.
  15. Elektroingenieur
    2,515
    3,288
    Three Touring
    You can’t disable the speedometer without altering the Combination Meter Assembly, either to disconnect the main display (left-hand LCD panel) or to modify its firmware. I don’t recommend this.
    To reduce distractions, however, you can disable most of the other displays, as I do:
    • On the multi-information display, in the Meter Customize settings, set Simple/Split Screen to Simple and Screen OFF to Yes. You can also disable many of the pop-up displays from this menu; see the Owner’s Manual for details.
    • On the Navigation Receiver Assembly, press the HOME button, then press the ⚙ (gear) icon in the upper-right corner, and then press Screen Off at the bottom center.
    • On the steering wheel, press the TRIP button repeatedly, until the odometer and mileage display at the bottom of the main display disappears.
    This will leave the main display showing the speedometer, outside temperature, and fuel gauge. The multi-information display will show warnings and messages, when needed, but it should be blank most of the time.
    RCO, Tyfly, pilotgrrl and 1 other person like this.
  16. RRxing
    RRxing Senior Member
    2,559
    1,835
    NEPA
    ...So they loaded up the truck and moved to Beverlee...
    kithmo, pilotgrrl and Mendel Leisk like this.
  17. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I'm intrigued by the question.
    I don't ever recall looking to see which gear I'm in in my PRIUS - I tend to be able to sense which direction I'm travelling. It'd maybe different if it was a sequential 8 speed Auto, but the PRIUS is essentially one "gear" - the HSD sorts it out automatically.
    But with speedometers, here in Australia, the Design Rule states "...The display of the speedometer must be located within the direct field of view of the driver and must be clearly legible both day and night ..." - ie, legally, it HAS to be there.
    RCO, Tyfly, pilotgrrl and 2 others like this.
  18. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    I think OP is from California, USPS state abbreviation CA. In internet-speak, Canada's TLD is .ca, Cali would be .ca.us, which is not a TLD.
  19. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I don't know what the Gen 4 is like, but I believe on the Gen 2 and 3 you could block the speedo with a little sticker on the mirror toward the front of the dash. Not that I would recommend or ever want to do that.
  20. alanclarkeau
    7,045
    7,593
    Don't quote me at the inquest - but I have a radio which I have on Classical FM all night - and the glare is annoying:
    solved by flipping a notebook cover over it when I head to bed every night - I did originally have a piece of card taped as a hinge, but the tape cracked eventually:
