Anybody Alive???
Discussion in 'Diesels' started by durallymax, Nov 27, 2010.
  1. wxman
    wxman Active Member
    636
    231
    Tennessee
    I would be the first to admit that hybrids generally make more sense in urban driving than small diesel vehicles. Speaking just for myself, I do very little actual "urban" driving since I live in a mostly rural area and the nearest large city is about 45 miles away. Furthermore, I make several 1500 mile trips per year (visits to family/relatives, mostly highway driving conditions), and the 335d is idea (IMHO) for these trips.
    The issue I'm having is the assertion that DPF is ineffective (and also the implication that gas vehicles don't produce PM). Based on my own experience and a myriad of studies (both U.S. and Europe), DPF is VERY effective, to the point that PM emissions (both in terms of particle mass and number) are significantly less than modern gas vehicles.
    The U.S.-spec 335d is certified at 0.000 grams/mile PM emissions @ FUL (120,000 miles - http://www.arb.ca.gov/msprog/onroad/cert/pcldtmdv/2011/bmw_pc_a0080288_3d0_l2_diesel.pdf ). I personally know someone who just purchased a new 2011 Ford Mustang GT and the inside of the tailpipes were coated with a layer of soot inside of 50 miles after driving it off the dealer's lot. If gasoline engines don't produce PM, where did the layer of soot come from?
  2. Trollbait
    12,800
    The diesel's longevity works against it when it comes to the cleaner perception. The long life means it is more likely to find an older, dirtier diesel on the road. Here, at least, I don't expect people to differentiate between a new Jetta and a 10+ year old one.
    I believe diesels currently have an advantage over petros in the future of bio-fuels. Bio-diesel appears to be more promising than ethanol. It also produces less particles.
    While I don't miss the black snow along the side of the road, the smaller particles produced during DPF regen, and always produced by a gasser, may be worse for the public health by being able to get deeper into the lungs. Some would call that ironic.
  3. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    SI engine, if not DI, do not emit Particles at all, and if not so, catalist will itself be promotor to its breakdown.
    And it is much more easy and cheap to keep a gasoline engine in good condition.
  4. wxman
    wxman Active Member
    636
    231
    Tennessee
    Then explain the layer of soot inside the tailpipes of a virtually new SI vehicle (PFI, not DI).
    That has not been my experience.
  5. wxman
    wxman Active Member
    636
    231
    Tennessee
    Direct quote from CARB (anything but a diesel supporter by the way)...
    PRELIMINARY DISCUSSION PAPER – PROPOSED AMENDMENTS TO CALIFORNIA’S LOW-EMISSION VEHICLE REGULATIONS – PARTICULATE MATTER MASS, ULTRAFINE SOLID PARTICLE NUMBER, AND BLACK CARBON EMISSIONS, CARB, page 10 (emphasis added)
  6. telmo744
    2,181
    769
    Portugal
    Soot coming out of a SI engine may turn black tailpipes, whether from quench zone if not yet heated up (HC not burned), whether from oil vapours (crankcase ventilation and/or consumption). The later is usually what may give trouble to a EGR system in a SI engine. Diesel EGR tend to clogg much more often.
    My fault, let me make a correction...even if properly running there is no such thing as zero PM, but many people, as me, can easily consider negligible emission. If you see Toyota european brochure Euro 5 for Prius, PM is slashed as zero.
    The same applies for the traces of CO in a diesel pipe:
    even if not expected, carbon monoxide is there, but seldom referred as being dangerous.
    Older diesels, like we have had in the past (Europe) are definitely worse. Injectors are a PITA, and the modern are extremely sensitive to contaminants in the fuel. To clean them, or to repair a pump, many euros may not be enough. Air filters and fuel filters are less cheap...and both are responsible for the PM if not replaced.
  7. wxman
    wxman Active Member
    636
    231
    Tennessee
    That's fine, but there are diesel vehicles in Europe that are certified as "zero" PM also (e.g., BMW F10 535d - VCAcarfueldata.org.uk - Search Results - Further Information ). So if you consider PM from gasoline vehicles as negligible, then there's no reason you shouldn't also consider PM from new diesels with DPF as negligible.
    Furthermore, certified PM emissions are measured under relatively gentle test cycles (FTP75 in NA, NEDC in Europe). There have been studies which show that under heavier loads (e.g., the US06 drive cycle), particle number (PN) emissions from SI vehicles approach and even exceed those of equivalent UNCONTROLLED diesel vehicles (PN emissions are FAR lower for a diesel vehicle equipped with DPF in this test cycle)...
    (Environmental and Health Impact From Modern Cars, Ecotraffic (Sweden))
    I agree that PM from gasoline engines likely is mostly semi-volatiles from HC quenching or lube oil, but semi-volatile PM has been shown to be about five times more toxic than solid PM (e.g., soot).
    I had a 2002 Jetta TDI prior to my 2010 BMW 335d, and I experienced no issues with the engine or drivetrain. I also have a 2003 diesel Ram truck with common-rail fuel injection system. I have over 100,000 miles on it and have experienced no issues whatsoever with the drivetrain. We do have a few diesel options in North America, so we're not totally clueless about maintenance issues of diesel vehicles as you European folks seem to think.
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I have a few business contacts living in the UK, Switzerland, and Germany. They also report the newest generation of passenger car diesel engine vehicles as being less reliable, in some cases much less reliable, than the older ones
    The legendary reliability of older diesel engines, especially the Cummins used in the Ram pickup trucks, had to do with simple design and robust construction. Once the emissions controls were tacked on, fuel economy plummeted and repair bills rose
    I know folks who also own GM Duramax and Ford PowerStroke trucks. Some with the Duramax had to replace injectors at around 140,000-180,000 km, usually a $3,500-$4,200 repair bill around here. The 7.3 Powerstroke seemed ok for most, the newer ones were horrible
    Let's not forget my neighbour with the 2009 Kenworth running a Cummins ISX with DPF. He replaced a 1996 Kenworth with a Detroit 60, and sorely regrets THAT decision
    Never mind fuel economy 40% lower. Reliability has been awful, sometimes the engine will get stuck in a regen cycle, which has already resulted in a DPF meltdown.
    He has had numerous confrontations with the salesperson who promised him the new Cummins would be as fuel efficient as the old Detroit 60. That sales guy now shrugs and admits they were wrong
    Now that the tractor has enough miles to be off major warranty, he is quite worried at how much the next repair bill will be. Assuming he can afford to keep driving it due to the horrific fuel economy
  9. telmo744
    2,181
    769
    Portugal
    Well, but regarding reliability studies, you have been lucky.
    Did you get a price for maintenance and parts of a petrol equivalent VW Jetta/BMW 3?
  10. wxman
    wxman Active Member
    636
    231
    Tennessee
    Perhaps. That's why I said it has not been MY experience that it is much more easy and cheap to keep a gasoline engine in good condition. My personal experience is that my gasoline vehicles have been MUCH more problematic than the diesel vehicles I've had.
    IIRC, in the case of the Jetta, the diesel parts and maintenance were somewhat more expensive, but the service interval was longer, so it appeared to be about a wash. Don't have any data on the 3-Series yet.
  11. durallymax
    durallymax Member
    142
    Under The Hood
    In the US the 2004-2009 emissions vehicles were unreliable. The 2010+ engines (provided they use SCR) are redeeming themselves, the engines are cleaner than ever. The SCR engines are cleaner and more reliable than the earlier emissions engines due to the reduced usage of EGR, and the new SCR engines are more reliable (in some areas) than the early diesels due to advanced technology creating cleaner more efficient combustions meaning less particles to contaminate the oil and increase wear on the engine. They also inject the fuel more precisely and over a longer period of time resulting in a smooth combustion cycle instead of one big bang.
    Now all of these additional features make them more complex resulting in more areas for things to go wrong.
    Again, this is pre 2010 emissions vehicles. The new SCR engines are waxing the older diesels when it comes to fuel economy. The new LML Duramax and 6.7L Powerstroke truely are getting 18-20mpgs on the highway. The First duramax (LB7) had no emissions controls and got 17-19mpg on the highway. It only had 300hp and 520lb-ft of torque. The New LML has 397hp and 735lb-ft of torque and gets as good if not better mpgs. Same goes for the powerstroke, the 7.3s got 16-18mpgs on the highway and only had 275hp and 525lb-ft. The new 6.7 has 400hp and 800lb-ft of torque.
    Then theres the cummins, the early ones got 18-21mpg on the highway and had 160hp and 400lb-ft of torque. The 6.7L Cummins gets maybe 16mpg on the highway and has only 350hp and 650lb-ft of torque which is much less than the 6.7 Powerstroke and LML Duramax yet it gets worse fuel economy. Why is that? Cummins doesnt believe in SCR, instead they make the engine suffer economy and reliability to keep emissions clean.
    I agree all 2004-2009 emissions diesels were terrible MPG wise and reliability wise, but the new age of SCR engines are kicking some serious butt.
    Bring it to me I do all 8 for around $2,000. But not all eight need to be replaced either.
    There is no set miles on when they need to be relaced or how many times they need to be replaced.
    The Injector issue was resolved with the next engine revision. It was a known issue, and GM did the right thing and stood behind them for 7 years or 200,000 miles. It was the first Duramax and by standards, a very early Common rail diesel. It was bound to have its hiccups and it did.
    Cummins ISX+DPF+Kenworth= FAIL. At least thats what ive seen around here, tons of people with KWs equipped with DPF ISX engines are having issues.
    The fact the he regrets trading a Detroit for a Cummins is a sad truth when it comes to the DPF ISXs
    We will have to see how the new 2010 SCR Equipped ISX will pan out.
    But there are still many DPF equipped vehicles running just fine. Everybody is quick to bash them just like in the 70s when CATs were put on cars.
    SCR also severly reduces DPF issues which is something overlooked by many.
    To all the foreigners out there picking my posts apart, thats nice. But I live in America, you live in your country, our emissions standards are different and they are the ones I am referring to.
  12. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    We're not picking your posts apart and it's nothing personal. We're on this forum because America is way ahead of Europe in the use of hybrids and we can get answers to any hybrid questions that we just couldn't over here.
    With regard to diesel cars, Europe is ahead of America and we're (me and my Portuguese friend) offering our extensive personal experience of this. Half of all cars here are diesel, some are good some are bad. Diesel has its place such as powering SUVs - the V8 Range Rover diesel for example is a great engine, but diesel isn't the panacea to road transport that some here are suggesting.
  13. hill
    9,014
    As I pulled out of the 5 Guys burger joint, I saw an Expedition sized pick up with a bumper sticker that said,
    "Just because there's smoke ...
    Don't mean it's broke"
    ok, I guess that means it's a rose scented healty substance?
  14. telmo744
    2,181
    769
    Portugal
    I would like to add profissional highway transportation, which in many cases is referred to technical/sales staff that go around the country visiting their customers, many kilometers on the road.
    But regarding (sub)urban driving, no way!
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    There are a lot of those vintage trucks out there, and some very unhappy owners.
  16. durallymax
    durallymax Member
    142
    Under The Hood
    Europe is way ahead of the US in diesel technology, most all of the US manufacturers use European parts and technology.
    Actually Europe is way ahead of the US in a lot of things. A lot of the equipment on our farm is from Germany because American manufacturers are not progressive, they just think that people want their equipment like the good old days. Well news flash I dont want to shift gears, I like my Fendt CVT, I dont want a rough ride I want Independent suspension, cab suspension and active seats.
    We just bough a new Claas Chopper too, and my parents are on a two week trip through Germany with Claas.
    Look at NASCAR and how many millions of dollars get stuck into developing an engine that still uses a carb.
    Ive always considered Europe to be way ahead of us, but thats just me.
    But IIRC the US emissions standards are currently much more strict. I consider that being ahead of Europe because our diesels are cleaner.
    But thats just me.
    Those people are as annoying as the guys with Truck Nutz, Diesel entusiasts, such as myself, are working to get these idiots off the streets. We spend hours every week reporting You Tube videos, writing letters to congressman, and preaching about how these people are dumb. Because Smoke is dumb and serves no purpose except to compensate for how small your penis is.
    I agree more and more with not owning a diesel strictly for driving in stop and go traffic, thats not where they shine. I used to say diesel for everything, but as of now, they aren't a good option for stop and go traffic. They are designed for long trips and anywhere power and torque are needed without using much fuel.
    Hence why the resale value on them is very low and many of them are getting transplants.
    Its also the reason why glider kit sales have gone through the roof.
  17. hill
    9,014
    Interesting view. Well, from one end of the spectrum (smoke belchers) to the other end of the spectrum (perfectly dialed in) ... we present:
    WAY more diesel than anyone will ever find a practical purpose for:
    Dyno's at 3,424 hp? I suppose it's like manufacturing nukes. Some folks want to know how over the top you can possibly get.
    :p
  18. guinness_fr
    guinness_fr Junior Member
    68
    france
    You are right that Europe is way behind the US (and California in particular) in terms of emissions standards. I'm guessing we have a strong diesel lobby behind this (especially in France because French manufacturers have only been working on diesel engines in the past 15 years, at least Volkswagen developed both their gas and diesel engines).
    This will change but it's taking too long for my taste...
  19. durallymax
    durallymax Member
    142
    Under The Hood
    The 24v71 is basically two 12v71s put together, there were actually production models of the 24v71, and a lot of home built ones too.
    The 12v71s were using in a lot of semis looking for big power back in the day, along with the 3408 CATs and the KTA Cummins motors. When people wanted 500-600hp back in the day. Thats why we now have extended hood models of trucks, they were originally built to fit these beasts but now have just become a personal preference due to their looks and ride quality of the front axle being out further.
    A V24 making 3400hp isnt over the top IMO. Many locomotives rely on V18, V20 And V22s making over 3,000hp each to get their power.
    And Since the guy polished the blowers and added bird catchers too them it looks like it has tons of power, but in reality a lot of people dont realized that all 2 stroke Detroit diesels were supercharged, they had to be. And for those who are familiar with drag racing and such, you have the blower nomenclature (6-71, 8-71 and such) that all came from the Detroit two strokes. 6-71 means the blower is designed to scavange 6 cylinders at 71cu in each. A 24v71 would have 4 6-71 blowers.
    I love the old two strokers, they are music to my ears, and I plan on putting a Buzzin Dozen in my old KW im restoring.
    Contrary to poular belief=, 2 stroke diesels are still everywhere and very common, they are the most effiecint internal combustion engines on the planet, currently. I think the worlds largest diesel dropped from first place, but it used to be the most efficient engine. over 5,600,000lb-ft of torque and it sips fuel at 3.8 Liters per second.
    I like the idea of clean diesel, many people complain about them how they dont have power, dont have economy, cost too much money and are too complex. Those people havent dealt with new ones. For how much extra money the emissions controls add to the MFGs cost, the MSRP doesnt reflect it. The power is better than ever, the effiecincy is going up and yes they are complex, but so is everything else these days.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    And you do realize that because these guys blow black smoke on purpose, the average person will then paint every diesel owner with the same brush?
    Much like how a relative handful of ignorant Prius drivers, especially the Pulse and GLide crowd, have resulted in every Prius owner being looked down upon. I won't even get started on how many Prius owners have run out of gas trying to squeeze every last drop out of the tank
    So while a handful of rednecks may think they are Cool by using their tune box to blow clouds of black smoke on command, the average person seeing this simply supports far stricter regulation.
    Indeed, a woman at the office who never in her life had an opinion about diesel engines, became a very strong opponent to them. Want to know what happened?
    June on a nice day, she was in traffic in her 2009 Chrysler Town and Country, windows down as it was a nice day. She doesn't know much about pickup trucks, but the decal "Dodge" was readily apparent as the truck roared past her
    This tool obviously had the tune box cranked, giant clouds of black smoke gushing out. She claimed the smoke was so intense she had to pull over and had a hard time catching her breath
    So, this ordinarily nice woman who would never hurt a fly, started writing letters to her MP and MLA about the danger of diesel exhaust. She even wrote a letter to the Federal Minister of Transportation. She is thinking of starting a petition as well
    Due to a relative handful of ignorant rednecks, you are losing "the hearts and minds." You had better do a lot better job self-policing, otherwise don't complain when tougher regulations get shoved down your throat
