Anybody has done a jdm engine swap? Need advice for my Gen3
Discussion in 'Gen 3 Prius Technical Discussion' started by framire, Oct 12, 2020.
  1. framire
    framire New Member
    Savannah,GA
    Hey guys! Please help, I have a 2013 prius with 205k miles that I bought without the engine, I do have the exhaust manifold and intake from the old one. I am looking to buy a low miles Jdm one for around $1200 looks very clean and comes with everything (exhaust mani, intake, throttle body, damper assy,Egr cooler and warranty. Question is, is this engine a direct replacement or there’s some stuff that I need to do to make it work? Any help will be appreciated. Thanks in advance
  2. framire
    framire New Member
    Savannah,GA
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You can get used engines for almost nothing from your local junkyard because they rarely fail. A "JDM" engine does no good in a Prius if you're wanting performance upgrades.
    framire likes this.
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    A JDM is a safe bet and is used by many shops but as 2k1 said there are plenty of good low miles local examples available too.
    No advice per se on the g3 swap but often it's the little things missing that make for the biggest headaches (sensors, connectors, missing harnesses, etc).
    GOOD LUCK!
    framire likes this.
  5. PriusCamper
    PriusCamper Senior Member
    11,217
    4,577
    Pacific Northwest, USA
    Last quote I got from a wrecker for an engine like this was $1500 retail and if I used my buddy's business to buy it wholesale I could probably get it for under $1k so you price is in range
    Main issue with putting in an engine is logistics of not having shipping hassles, especially if it arrives damaged. And you don't have a core, so core deposit might be a hassle too...
    framire likes this.
  6. orenji
    orenji Senior Member
    5,884
    3,486
    Right hand cars have some items on the opposite side so wiring maybe an issue as well as clearance.
    framire and Mendel Leisk like this.
  7. framire
    framire New Member
    Savannah,GA
    I’ve only found 2 used engines locally from lkq with more than 140k miles and they want $1500 that’s why I am leaning towards the Jdm. There’s a bunch of older prius local junkayards but they got the 1.5 engine and I need the 1.8
  8. fotomoto
    5,602
    3,781
    So. Texas
    HOLY MOLY. I recently got a low miles (60k) engine with an IMA EV motor still attached for a Honda hybrid for $180 plus $175 shipped to my driveway. No kidding. OK, it was from a rust belt car so it had some light corrosion but still......
    Supply and demand at work I guess. AFAICT, the Honda Insight engine has no history of known problems (other than wear&tear) while the gen 3 ICE has a growing issue with head gaskets failures. Modern companies like LKQ can easily determine what sells and what doesn't and adjust pricing accordingly.
    framire, search here for 4gen engine swap threads. I haven't kept up but AFAIK it's a fairly straightforward swap into the gen 3. If so, that should help widen your searches. I see some on ebay for $1k shipped w/ 60k miles.
    GOOD LUCK!
    framire and PriusCamper like this.
  9. PriusCamper
    11,217
    4,577
    What year is the Honda Insight engine?
  10. fotomoto
    5,602
    3,781
    So. Texas
  11. tony_2018
    tony_2018 Member
    205
    61
    Just make sure you get the 2zr for a prius/ct200. No other car. It should have a placement for an electric water pump. If it doesn't move on.
    PriusCamper likes this.
