anybody know how to instal in 2015 prius c cruise control ?? not 2012-2014
Discussion in 'Prius c Technical Discussion' started by levani, Feb 11, 2020.
  1. levani
    levani New Member
    georgia
    2015 Prius c
  2. strategy400
    strategy400 New Member
    25
    Victorville, CA.
    2015 Prius c
    rostra (period) com (forward slash) manuals (forward slash) 250-1836_Form5350B (period) pdf
    They won't let me post links so you'll have to figure it out
  3. strategy400
    25
    Victorville, CA.
    2015 Prius c
    I just installed CC in my 2015 over the weekend. One tip: check the pins on the wires before inserting them into the connectors. They are keyed, and my kit came with 2 brown wires with differently keyed pins. Make sure you are using the right one before inserting because it's hard to get them out once they are inserted. The ECM connector on mine appeared to be reverse keyed from the others. You don't want any issues with the ECM pins/connectors or you may not have a car to drive. My CC is working as expected and lowest speed I can lock in is 23 mph. Pretty nice!
  4. strategy400
    25
    Victorville, CA.
    2015 Prius c
    The keyed connector. For my 2015 Prius C I had to insert the brown wire pin in that top corner of the connector (right next to the electric tape)
    The 2012-14 prius C is different, the wire goes to the top connector in the ECM/ECU
    Rifaqat Shah likes this.
  5. strategy400
    25
    Victorville, CA.
    2015 Prius c
    This one has the 2015 instructions: http://www.rostra.com/manuals/250-1836_Form5350B.pdf
Loading...
