Anybody know what's causing this sound?
Discussion in 'Gen 2 Prius Main Forum' started by robert Kwasny, Oct 23, 2023.
  1. bisco
    52,820
    maybe a recording under the hood is appropriate as someone else opens the driver door.
    the actuator is ahead of the driver, near the bulkhead. there should be a good buzzing
    52,820
    since you're getting an intermittent abs warning, it might be worth scanning for codes
  3. robert Kwasny
    robert Kwasny Junior Member
    35
    so cal
    The video was recorded with the motor off not in ready mode with my friend sitting in the driver seat. Taking the car in for a scan tomorrow I'll let you all know what the results were
    52,820
    all the best!
  5. robert Kwasny
    35
    so cal
    Here's the bad news wondering if I should try to flush the fluid first before replacing the pump.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,068
    6,936
    Texas Hill Country
    A flush may clear it up for a day or two but otherwise is a waste of money and effort that will be repeated later.
    You should take it to Hybrid Pit for a second opinion and likely a better price.
  7. robert Kwasny
    35
    so cal
    Well it's been 8 months since my first post. I flush the brake fluid and the ticking noise stopped for a while but then came back.
    I can hear the pump motor while the clicking noise is happening. The Toyota repair shop stated the clicking noise was from the Hybrid battery ABS relay. I have a used pump coming from eBay but before I install it I'd like to know what that clicking noise is. As far as I know there is no ABS relay in the HV battery pack. Had that out twice already in the last 4 years for reconditioning. Ticking noise is coming from under the car at a block where the brake lines meet on the passenger side. With this new information I hope somebody can help me understand what's happening. Thanks in advance.
  8. rjparker
    11,068
    6,936
    Texas Hill Country
    The new information about the brake line “block” location tends to confirm this.
    Further confirms brake booster/actuator.
    Fix the brake booster.
    #28 rjparker, Jun 14, 2024
  9. robert Kwasny
    35
    so cal
    Just what I needed to know thank you.
