Anybody switch the hybrid battery charge mode?
Discussion in 'Prime Main Forum (2017-2022)' started by ChachabahPrime, Feb 28, 2017.
  1. HypersonicPrime
    75
    59
    NC, USA
    For the OP, here's an interesting test I did. I think CHG/EV alternation could result in notably better fuel economy in many scenarios.
  2. Why do we need to have three threads on charge mode going at the same time?
  3. bwilson4web
    16,548
    It is not uncommon to find multiple threads on a subject that died out. Then someone 'new' comes in and wants to share their recent efforts. Usually, they pick one thread and resurrect it. In this case, one user has resurrected multiple threads that had discussed CHARGE mode and then made a link to his experiments. Not an optimum practice because it raises the question of:
    phlack likes this.
  4. HypersonicPrime
    75
    59
    NC, USA
    Without linking them together, people may only read one thread and be misinformed. At least I'm not duplicating posts. If there was a way to add a link to a thread without resurrecting it, that'd be nice, since the related posts section doesn't work that well.
  5. bwilson4web
    16,548
    Let me suggest a more effective technique used in written papers:
    1. Start a clean thread with your paper and analysis.
      1. The short title should reference original discovery.
      2. Topic paragraph, a type of abstract, summarizing the body.
      3. Body of research, methods and conclusions
      4. Summary paragraph, like the first but more refined.
    2. Add relevant 'footnotes' when an earlier post has something that relates to your work and a link to it. If you'll use "@<username>", the author will get a notice to follow-up if needed.
    I'm interested in effective communications that bring new insights. Unfortunately tagging the end of 'dead threads' brings a lot of baggage and no context. It suggests you asking us to read every post in the previous threads and somehow make connections with your work.
  6. Dave7
    Dave7 Junior Member
    45
    CT
    2020 Prius Prime
    to me the big advantage of CHG mode is to increase overall range. Right before stopping to fill the gas tank run the CHG mode, then with the added EV miles you have almost maximum range. Almost full battery and full tank. Good for long trips.
    benagi likes this.
  7. fusion
    fusion Junior Member
    26
    San Francisco
    2019 Prius Prime
    It takes energy to make energy, there is no free ride. Unless you are going downhill, I don't think it's worth using.
  8. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    You'd be wrong.
    Confirmed
    Turns out this is not necessary. The engine has the power needed, even on long steep hills at high altitude.
    Confirmed
    Confirmed through years of use, including yesterday.
