Anybody's TPMS lasted longer? (9.5 yrs here)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wjtracy, Jan 7, 2016.
  1. Patrick Wong
    18,210
    6,518
    Did you provide the amazon.com link just to indicate a potential source; or did you buy and install those particular sensors yourself?
    52,858
    great price.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    No I did not buy it yet I was just thinking it might be the way to go. Just posting review of another Prius. Correct me if I am wrong, to install this device goes inside rim, so you'd have to take the tire off. and you need someone who has the program device for setting it up for Prius. I will call my local shop soon to see what they propose.
  4. Mendel Leisk
    42,351
    You're right; in conjunction with tire replacement a good time is. (Channeling Yoda)
    Amazon lets you enter your vehicle to verify fit; fwiw says 2010 Prius is compatible too.
  5. boscohoney
    boscohoney Junior Member
    16
    Urbandale, Iowa
    I have a 2005 prius 120000 miles just bought the second set of new tires and never have had a problem with tmps issue
  6. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Do you have TPMS? above Patrick indicates TPMS was not on 2005- Prii
  7. boscohoney
    16
    Urbandale, Iowa
    I did not know this on the 2005. But I also have a 2012 prius 42000 miles on it and had a new set of tires put on it about 40000 miles and did't have a problem with it
  8. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    OK well there is a little button battery inside the device in each tire, so after about 8-10 years you gotta replace the whole device and the cost at Toyota is probably $100+ per tire. And you can't disable the flashing light on the dash.
  9. boscohoney
    16
    Urbandale, Iowa
    they go bad is really necessary to have them relaced? Car should not stop running should it?
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Just that the warning light is on and cannot be disabled...don't know if states require fix for inspections.
  11. boscohoney
    16
    Urbandale, Iowa
    we have no inspection in Iowa
  12. Mendel Leisk
    42,351
    Still, it's good if the price is coming down. The concept is attractive, just the implementation is expensive/complicated.
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Had an employee call in once that they would be late: flat tire. The two truck was coming to put on the spare. Got a call a couple hours later that they were at the dealer and won't make it in to work at all. I asked why and the person said there was a light on the dash and they will not drive it with an engine light on. :mad: TPMS, I hate you!
  14. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...I got hit with frying pan today...tape only worked 2 days
  15. Mendel Leisk
    42,351
    We drive all winter with that terrible tpms light on. I mean, just down and to the right, there's lights telling you the status of the passenger seat air bag; no one pays them any mind.
  16. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    #36 wjtracy, Jan 10, 2016
  17. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Wow. Talked to my mechanic. They want $60 to test the four tires for bad sensors, $170 per tire to replace the bad ones, and $60 for reprogramming. NOT needed to pass inspection in Virginia, thank gosh.
    Might try one of the wireless systems on Amazon. There is a smart phone system called FOBO that a few here have mentioned, and the Tesla guys have been using/doing some group buys.
    #37 wjtracy, Jan 15, 2016
  18. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Wow! Go get 4 Dorman 974-033 from Amazon for $31.49 each.
    Then go to Tire Rack - Your performance experts for tires and wheels and search for an installer. I found one who charged me about $10/tire to replace the sensors. I used my own Techstream to register the new sensors. Be sure to record the ids on the new sensors before they're installed.
  19. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Yeah maybe tire places are the way to go. I have a TireRack installer so he should be willing to help.
