Anyone able to use Treo 755 with bluetooth?
Discussion in 'Gen 2 Prius Audio and Electronics' started by emtownsend, Jun 12, 2007.
  1. emtownsend
    emtownsend New Member
    111
    Post Falls, ID
    I have successfully connected my Samsung IP-830w phone with my Prius using bluetooth, but for some reason I cannot connect my wife's Palm Treo 755p which is brand new with bluetooth version 1.2.
    The phone says it is successful but the car seems to still be waiting... Any suggestions? Anyone with success using a Treo 7 series phone?
    Thank you!
  2. Compfool
    Compfool New Member
    <div class='quotetop'>QUOTE(emtownsend @ Jun 11 2007, 11:39 PM) [snapback]459957[/snapback]</div>
    I have a Treo 700W with Verizon and I have been only able to connect using the Hands free feature. I have not been abele to get the phonebook and other features to work.
    Adam
  3. Bearcatzzz
    Bearcatzzz Junior Member
    97
    <div class='quotetop'>QUOTE(emtownsend @ Jun 11 2007, 09:39 PM) [snapback]459957[/snapback]</div>
    Try making a phone call with the phone during the "waiting" time. The bluetooth should kick in and take over the call.
  4. Bearcatzzz
    97
  5. 2PriusFamily
    2PriusFamily Junior Member
    Same problem with car hanging on passkey. I solved this by following hidden "Tip" in the Treo's bluetooth menu: Once you've paired from the phone and the phone sees the car as a "Trusted Device", navigate to "trusted devices", scroll to highlight the car, then Menu key (lower right) and "Connect."
    Good luck!
  6. cranston
    cranston New Member
    <div class='quotetop'>QUOTE(2PriusFamily @ Jun 13 2007, 11:43 AM) [snapback]460932[/snapback]</div>
    Got my new Treo 755P and had the same problem...as above, after navigating to trusted devices, highlight the one for the car (mine is HANDS FREE by defalt), go to the top left (where there would normally be a menu and click, and a secret menu will appear, select CONNECT).
    Cranston
  7. emtownsend
    111
    Post Falls, ID
    <div class='quotetop'>QUOTE(cranston @ Sep 13 2007, 09:57 PM) [snapback]512299[/snapback]</div>
    Thanks for all the tips! I too stumbled across that method just out of poking around (and never re-posted, sorry!). Turns out I sold my IP-830 because I really liked my wife's 755p so now we both have 755p's. The signal strength and bluetooth are both noticeablly stronger on the 755p. The 755p on the Prius sounds crystal clear. I did have to go into the Prius service menu and turn up the bluetooth microphone a couple notches, but now all is very very good.
  8. HenryE
    HenryE New Member
    My 2004 has been working perfectly with various BT phones, including the Treo 650. The 755p arrived, paired properly, and also worked just fine.
    HOWEVER, not smart enough to leave well enough alone, I decided to update the phone book in the Prius. I erased the old one, and now cannot transfer the new one. Perhaps the wrong procedure?? I'm simply trying to send the CONTACTS database via BT to the highlighted HANDSFREE car - using the utility in ZLauncher. They connect, work for a minute or so, then the car display says TRANSFER FAILED. Is there another way? Factors:
    Connectivity is fine - pairing is easy and calls sound excellent.
    I *can* transfer one Contact at a time, so it's almost certainly a procedural error...
    What am I doing wrong?
  9. emtownsend
    111
    Post Falls, ID
    <div class='quotetop'>QUOTE(HenryE @ Oct 25 2007, 10:16 PM) [snapback]530561[/snapback]</div>
    Hum.... Can't remember, but I may have gone into contacts as if transferring one at a time, but did a "select all" and then sent.....
  10. HenryE
    HenryE New Member
    <div class='quotetop'>QUOTE(emtownsend @ Oct 26 2007, 11:25 AM) [snapback]530727[/snapback]</div>
    I must have a blind spot. After examining menus, I could not find a "select all" option. That's why I tried to transfer the file itself... I'll look again. And again.
  11. macfarlj
    macfarlj Member
    Silicon Valley, CA
    I had major issues with Sprint Treo 755P but was able to get the thing paired by forcing a call wich a quick dial while it was trying to find my phone. Once it picked up my call it works like a charm. Happy camper now.
  12. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    I got mine to work by making forceing a call while the car is searchig. It works great now.
  13. HiHoStevo
    HiHoStevo Airport Bum
    40
    Las Vegas, NV / Cedar Hills, UT
    I think I am missing part of the conversation...
    However, I also have a Treo 755 which paired just fine with the BT in my '05 Prius.
    However, I would love to have a link to step-by-step instructions on how to transfer my contacts in the Treo 755 to the Prius's Phone book!!!
    Thank you
    Ps. I have been able to send "data" to the phonebook in my car, but whether I send one contact at a time or one category the result is the same. I get part of the name and then a bunch of vertical lines where the number should be. On a few of the contacts the number actually came through, but 95% were just vertical lines.
