Anyone added dedicated cellphone air vent in center shelf?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Toyonka, Aug 9, 2015.
  1. Toyonka
    Toyonka Junior Member
    75
    So Chevy have realized what I also realize – in hot climates (I'm in California) cellphone battery life and performance drops when the phone is hot, sometimes an incredible amount. They have added a dedicated mobile phone cooling vent: Chevrolet adds an air conditioner to its cars to boost mobile phone battery life | Daily Mail Online
    I have Android Auto (via Pioneer) and the phone sits on the center foot shelf under the gear selector. Has anyone tried to add an air vent here by diverting air from the main duct?
    If not has anyone any advice on how to do this? I suspect the best location to share air with would be the passenger footwell duct.
    Thanks!
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Don't get sucked into these marketing shams.
    milkman44 likes this.
  3. Toyonka
    75
    Err... this is a real problem that I had before I'd heard of the Chevy 'feature'. It's very sincere. If I am driving with my phone in the sun or charging, the processor slows itself down to prevent overheating, which slows everything down including Android Auto or answering calls. Even worse is it destroys the battery. Again, very real issue which I thought I made clear above.
    Hoping for constructive and smart suggestions on how to rig something internally.
  4. frodoz737
    4,297
    2,348
    33
    Respects...but don't leave it in the sun. It's over 100° here (and every summer) and no known issues unless you leave your device in the closed vehicle all day. I wish you the best with your pursuit/mod, but your are being drawn in.
  5. gliderman
    gliderman Active Member
    751
    223
    Most of the after market car phone mounts are vent mounts. Problem solved.
    HybridBull likes this.
  6. bisco
    49,429
    why would the phone be less comfortable than you? my car is a comfy 75 degrees inside.
  7. Toyonka
    75
    We might have to agree to disagree.
    1. When a phone is actively charging, it heats up a great amount. Add to that direct sunlight, and you've got a device much hotter than the interior air temperature.
    2. Android Auto requires that the device be plugged into the Pioneer head unit. This forces it to charge. The head unit shows the phone display, so you do not use an air vent mount as the phone screen is not used.
    If you don't have any answers on how to do the modification I'm considering, that's fine, there's no need to respond to this thread which is looking for such ideas.
    Thanks anyway!
    #7 Toyonka, Aug 9, 2015
  8. bisco
    49,429
    i can see the sunlight being a problem. i keep mine under the bridge. it's charging in the same environment as my home.
  9. Toyonka
    75
    All phones, homes, locations, charging situations, sunlight angles, apps running and a dozen other variables are different. I have a Nexus 6. Big phone, big battery, thirsty processor, lots of apps installed. Trust me on my needs, and if you can contribute to the solution then great!
    Hasan likes this.
