Anyone can confirm bolt pattern on 2023+ models?
Discussion in 'Gen 5 Prius Technical Discussion' started by TE37SL, Mar 12, 2023.
  1. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    So, @flarecde, which options do you have? Do you have PVM, digital rear-view mirror, sunroof, etc.? Perhaps you can post pics in the Gen 5 owners thread when you get a chance.
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    dbat23 and Gokhan like this.
  3. flarecde
    flarecde Member
    59
    68
    NY
    2023 Prius
    Limited AWD-e
    It's a pretty well optioned Limited. Pano view, parking assist, digital mirror, sun roof, heated rear seats, door and mud guards, all weather covers. It was the first one available around here and I plan to keep it a nice, long time.
    I only have one picture I took for my family, the weather's been awful. I can take some more tomorrow, anything specific?
    Kalianyia and Gokhan like this.
  4. Kalianyia
    Kalianyia Junior Member
    26
    17
    • How does it compared to your previous car?
    • Overall driving impressions?
    • Most surprising thing?
    • What's your mileage been like (and your driving habits)?
  5. dbat23
    dbat23 Member
    53
    37
    WI
    2020 Prius Prime
    I might have this wrong but using Google Translate, I see one column heading is Hole Diameter. Would an XSE's 19" wheels with 19mm hole diameter preclude using SE's 17" wheels which have a 14mm hole diameter?
    Salamander_King likes this.
  6. Salamander_King
    11,024
    8,980
    New England
    Good catch! Yeah, from the spec, looks like the 19" wheel has larger bolt holes. What I don't know is if the stud (or what Toyota calls hub bolts even though they are not real hub bolts) diameters are also larger on the trims that comes with 19" wheels. If the stud diameter is less than 14mm, then it should still fit on the SE's 17" wheels with 14mm holes. But... if the bolt diameters are the same, then why would they make the 19" wheel bolt holes bigger???
    I wish someone with SE and XLE to try swapping the wheels... But that would be too much to ask?
    dbat23 likes this.
  7. Hammersmith
    Hammersmith Senior Member
    2,493
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Man, I hope not. lol
    I just ordered a spare wheel for my Limited(I was already ordering things and wanted to bundle as much as I could to hit a free shipping threshold), and I hope I got the right one if they're different.
    Really wish Toyota finishes up adding the 2023 models to the parts catalog soon.
    dbat23 likes this.
  8. dbat23
    dbat23 Member
    53
    37
    WI
    2020 Prius Prime
    It would be good to know; I'm planning on doing the same. I've got a 2023 XSE supposedly arriving late-June or mid-July.
  9. Hammersmith
    2,493
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You wrote XSE, so I'm assuming you're getting a Prime? Just checking that you've read the other thread that shows you won't be able to fit the spare below the floor of the trunk. You can always strap down the spare above floor of the cargo area, but there's not enough room below it without building something to raise the floor.
  10. dbat23
    dbat23 Member
    53
    37
    WI
    2020 Prius Prime
    Yup, the Prime is supposedly in the build stage. For a "spare", I'm hoping to eventually get a set of 17" tires/wheels assuming TireRack (I reached out to them) gets a 2023 Prime to do their measurements. For out of town trips, I can either strap a spare, or more likely take the wife's '22 RAV4 Hybrid.
  11. Gokhan
    6,714
    2,672
    Paramount CA
    No, the small holes are only for the 17"-steel-wheel option in Japan. In the US, both the 17" and 19" aluminum wheels (the former with wheel covers) have the same large holes.
  12. Salamander_King
    11,024
    8,980
    New England
    Oh I see. The small 14mm bolt holes are only for steel wheels. Then I wonder if Japanese Z grade Prius PHEV with factory option 17" steel wheel comes with a thinner diameter hub stud? That would be strange.
    In any case, if the US version does not offer 17" steel wheels, then swapping SE 17" alloy wheels with XLE 19" alloy wheels is doable.
    #32 Salamander_King, May 9, 2023
    Gokhan likes this.
  13. Trollbait
    12,831
    Maybe they are using wheel bolts over there.
  14. Gokhan
    6,714
    2,672
    Paramount CA
    Yep, I don't think there is a difference in the US trims, and it should be swappable.
    17"-steel-wheel-version hubs are probably identical as well, as the hub studs are M12 × 1.5 and would pass through 14-mm through holes in the steel wheels.
  15. Gokhan
    6,714
    2,672
    Paramount CA
    Very unlikely.
  16. MaxT
    MaxT Junior Member
    27
    45
    Georgia
    2023 Prius
    My Prius Limited has 5 on 114.3.
    Tried to reuse my 22 Limited spare but it would not fit since it is 5 on 100.
    My 23 Crown has 14mm bolts, so was surprised by that.
    The hub on the Crown is almost 1/2 inch wide so not too bad putting a tire back on but you do have to get those holes aligned close before those bolts screw in easily.
    Gokhan likes this.
  17. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    I almost thought you could use the rather efficient Volt rims but they are 115mm, how stupid
    Gokhan and bisco like this.
  18. CruisnGrrl
    CruisnGrrl Active Member
    151
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Chevy being chevy. they have to be different than everyone else.
  19. Gokhan
    6,714
    2,672
    Paramount CA
    I think you can use a 114.0-mm or 115.0-mm PCD on a 114.3-mm PCD spec without an issue. The wheel-runout spec is 1.2 mm, which is almost twice the 0.7-mm difference. If you are careful when installing the wheel, there could be virtually no runout.
    #39 Gokhan, Jun 13, 2023
  20. Rmay635703
    2,704
    1,729
    2013 Chevy Volt
    Yeah, sorta kinda but usually not
    I did that once and very carefully kept everything centered and it worked but when I did a tire rotation I broke a lug as things splayed out very slightly
