anyone change tires yet? mpg decrease?
Discussion in 'Prius c Fuel Economy' started by tonia taffaro, Jun 13, 2014.
  1. tonia taffaro
    tonia taffaro Junior Member
    83
    i have a 2012 prius c with 72k miles.
    when i bought teh car, it took a while for the fuel economy to increase. i drive 100 miles a day at 85mph and topped out at 52mpg. pretty damn good, if you ask me. im all interstate with very little city driving.
    2 years later, its time to get new tires and ever since i changed them, my fuel economy has decreased to 45mpg. i plan to give it a few weeks to see if it increases but I was wondering if anyone else has had this problem.
    my new tires are goodyear fuelmax assurance - supposed to be great for fuel economy.
  2. Raidin
    Raidin Active Member
    238
    183
    Houston, TX
    I changed my tires to Hankook's Optimo H426 or whatever they're called. Cheap tires because I am not keeping the car for long. I'm down about 4 mpg on average.
  3. Mendel Leisk
    42,228
    What were your original tires?
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    A decrease is normal after a tire change. Part of the decrease is due to a difference in circumference between the old and and new tires.
  5. tonia taffaro
    83
    will it increase after some wear?
  6. tonia taffaro
    83
    good question, i dont know
  7. xpcman
    1,302
    295
    Probably. I would also check the tire pressure and inflate them to something like 38 front 36 rear.
  8. Raidin
    238
    183
    Houston, TX
    As I understand, there are two tires used as OE for the Prius C in the US. I got mine with the Goodyear Assurance Fuelmax from the dealer (as a new car.)
  9. tonia taffaro
    83
    i just bought those EXACT tires!
  10. Raidin
    238
    183
    Houston, TX
    Somewhere on this forum, there's an "ultimate tire guide" thread. It mentions that 2 Michelin tires are the best for fuel economy at 15" and 17" wheel sizes. I may consider those next time I need tires, but you got what Toyota felt are the right choice for the car with respect to a good balance between ride/handling, fuel economy, and noise. Good choice!
  11. tonia taffaro
    83
    i'll look for that, thanks
  12. Raidin
    238
    183
    Houston, TX
    I tried to find it but couldn't in the short time I had. I'm hoping someone who knows where it is will link it.
  13. DKTVAV
    DKTVAV Active Member
    510
    101
    I posted a link here, I hope it's the right one.
    BTW, I think my MPG decreased after changing to Ecopia EP422 but they're much more quiet than the original tires.
  14. EcoNut1
    EcoNut1 New Member
    Roy, Utah
    2014 Prius c
    same here, I have the exact same tires,
    how do you like them?
  15. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Switched to Ecopia EP422's as well. Much quieter tire. I have them set at 35 PSI, and get between 400-420 miles on a tank. (I fill up when I get low gas warning beep). They have a soft sidewall so you get that weird cushy/spongy feel when turning. Might increase to 38 PSI and see how things turn out.
  16. mahout
    mahout Active Member
    655
    116
    NC
    its not normal unless you change tire size. The only change we see here with literally thousands of new tire changes is you can expect less mpg only if you mount heavier tires or go bigger on tire diameter. Mount narrower tires of same size with less weight and you will increase mpg. Thats why you go slightly smaller tires when the choice is extra width, If your mpg decreases its because the new tires are bigger thanks to more tread but its not statistically verified. Its merely because the tire weight has changed or in rare cases a tread design will change mpg but thats due to aggressive treads that aren't smooth and round. And don't forget that you may have to change tire pressures to get same results.
    Use the spec data on tire rack.com to get the dimensions, weights, and revs per mile to get good comparision. While you're at it check their buyer opinions and performance data. Its like everything else. research counts.
    And yes as you wear the trad it often, but not guarnteed to get better but its not really actual data. the tire rotates smoother with less rolling resistance but naturally more often per mile so your odometer thinks is going further between fillups. Not really that significant. You'll have more result with a good waxing. Really, just ask the salt flat racers. Or NASCAR.
    #16 mahout, Jun 30, 2014
