Anyone doing oil change without ramps or stands
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sfl109415, Jul 9, 2009.
  1. icarus
    icarus Senior Member
    4,884
    976
    earth
    I was skeptical until I spoke with my GOOD foreign car mechanic,, and he was using one on the BMWs and Benzs.
    You can by them at most marine stores for ~$50,, West Marine,, or Gander Mtn. etc. The first time I used it,, I pulled the plug and ONE drop came out!
    It was explained by the same mechanic that the pump was even more effective at getting sludge out of the bottom of the pan since it actually sucked up the sludge,, as opposed to just letting it flow. Seems real to me!
    Icarus
    PS,, Like this: http://www.autosportcatalog.com/auto-accessories/6-5l-hand-pump-oil-extractor-2.shtml
  2. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    That's a pretty slick device. I wouldn't even have to drive around back. :cool:
  3. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    you need to wipe them out with kerosene b4 putting in dishwasher
  4. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    after all these years and still cazy about nipples
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    No, the residue *adds* to the flavor. You're not much of a chef, are you?
    A time tested and safe means of raising the car. You can actually put 2x6's under the rear tires too, so the car remains level. This is helpful for the cvt fluid change
    Yeah, I bet you do
    :rolleyes:
    I use the Mityvac one
    http://www.mityvac.com/hq_images/07400.jpg
    I recommend the hand pump version. Although the shop air one works better - stronger vacuum - it's a PITA to always hook up shop air just to run it. Unless you intend to use it a LOT
  6. sfl109415
    sfl109415 New Member
    TN
    I usually buy them online for my Tundra, the Prius prices look to be about the same. They both run between 4 and 5 bucks each for Toyota filters. I just use conventional 5w30 in my Tundra and will use that in the Prius as well.
  7. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    We use Bosch filters, picked up at the local auto parts store.
    I could order OEM filters, but why?
  8. Verde
    Verde New Member
    16
    CA, USA
    No offense, but I'm still skeptical. I have read for years that these devices simply don't extract enough of the oil or access pockets of sludge. Many instances of the withdrawn volume being significantly less than the equivalent drained volume. Perhaps the technology has changed a bunch but it still seems that gravity is your friend. So long as you open the drain plug when the engine is still warm, and have the patience to wait for the small drips to come to an end (minimally 1/2 hour) I still believe you get the best drain.
  9. icarus
    4,884
    976
    earth
    Verde,
    As I suggested,, I too was quite skeptical,, but I have since used this pump for all kinds of engines from large Diesel Gen Sets,, to lawn mowers. As I said,, with the Prius,, I pulled the plug on the first change,, and got two drops,,,and then nothing. Besides,, have you ever seen a lube monkey wait 1/2 hour to get the last few drops? I don't think so!
    Also,, you can manipulate the hose around the oil pan and find the lowest point.
    Icarus
  10. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Seems like a very good price BTW. Is this the best price/place to get this stuff?
    Icarus
    PS,, Like this: http://www.autosportcatalog.com/auto...ractor-2.shtml
  11. donee
    donee New Member
    2,956
    198
    Chicagoland
    Need I say more ?
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    Nice nipple
  13. ETP
    2,806
    1,170
    Auburdale FL
    I prefer two.
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    Gawd you're picky!
    :rolleyes:
