Anyone else find the new SKS door handle sensor annoying?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by silentak1, Aug 9, 2010.
  1. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    It was an initial gripe with me too. My prior car had a "trunk" button on the remote so if you were loaded down with packages, you could press it and the trunk would gently open. That way, you wouldn't have to "disarm" with 2 presses on the remote and then lift the hatch. I also think the same convenience should be in the cockpit. Why not have a latch next to the gas port release to "pop" the hatch if you wanted to unload the back of it? Of course, this would only work if the car was in "P".
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    I don't have to use two presses on the remote to "disarm". I leave my remote in my pocket. All I do is walk up and lift, and the hatch automatically unlocks. I can't understand why you would use the remote unless you only have the single door SKS. If that is the case, then I understand your complaint. The single door SKS is better than the old non-SKS, but if it were me, I'd have three-door SKS on all Prius. It's a great feature.
    Tom
  3. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    um a Prius IV is supposed to have a sensor in the hatch lol
  4. beantowncruiser
    beantowncruiser New Member
    Boston
    No, you're not alone on this. The technology is very cool, but it sometimes tends to take a second or so before it locks, and sometimes it doesn't. I have on a number of occasions, had to turn back around and touch the handle again to get it to lock. Now I just stand there and wait until it locks, sometimes having to touch it again. Although the touch sensor is more streamlined, I agree that the button was more effective.
  5. Tideland Prius
    16,547
    Agree although I do like the clean look of the touch sensors.
    With the old Prius, I can close the door AND push the black button at the same time with one of my fingers. This means the door locks the moment it closes (if you time it right and it's pretty easy to get it right).
    With the new Prius, I have to close, then touch the sensor and wait because it doesn't always lock. I've gotten into the habit of touching BOTH the top and bottom sensor and so far that has a much better success rate.
  6. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    I have no complaints about having to wait a bit to lock the doors... I have to wait for my beloved passenger to hurry up, gather her stuff, get out, and close the door anyway. ;) Not sure how it is that I'm always the first out, though.
    Though I wouldn't mind a more intelligent behavior if you try to lock it with a door still open. Yes, it's good for it to do something different to make sure you know that not all the doors are closed (in case some door just *looks* closed), but it sure would be nice if you could press the lock button, then have it lock when the last door closes, without the car throwing a hissy-fit. I think my parents had a Ford that did this - it beeped a little differently if you locked it with a door open, and then beeped again when the door closed as it locked the doors.
  7. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    To clarify, did you change your key fob to open all doors, or did you find a way to have them open as the Gen II did??!!
  8. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
  9. robertk328
    robertk328 Member
    206
    36
    Northern Virginia
    When I touch the drivers-side door handle, all doors unlock, including the trunk. But I cannot touch the trunk or passenger handles to have it unlock. Drivers-side first, and all will unlock.
  10. qbee42
    18,058
    3,079
    Northern Michigan
    You must have the single door SKS. Bummer.
    Tom
  11. robertk328
    robertk328 Member
    206
    36
    Northern Virginia
    No big deal, I just stop at the drivers door first, touch it, then move on. Otherwise I can use the fob. :) I think you need the IV or V to get the multi-door.
