Anyone else have bad luck with Dorman combination meters?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 3prongpaul, Jan 12, 2015.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    I installed 2 "rebuilt" Dorman combination meters (instrument clusters) on 04/05 Prius in the last few days.
    Both customers called me this morning (coldish morning) and said displays were blank then came back on once warmer.
    Anyone seen this behavior with Dorman reman combo meters?
    Here is how to remove the dash top and combination meter.
    #1 3prongpaul, Jan 12, 2015
    52,812
    someone said luscious is only installing new ones now, because rebuilds were refailing.
  3. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    #3 exstudent, Jan 15, 2015
  4. stonerider
    stonerider Member
    107
    Lompoc, CA
    Isnt' the combo meter under Toyota extended repair campaing, 10 years?
  5. 3prongpaul
    956
    735
    The campaign is 9 years from date car first put into service, so 04's and some 05's are not eligible. AFAIK Luscious Garage has never used Dorman rebuilt meters, they were having an someone else refurbish them.
  6. exstudent
    2,214
    905
    Torrance, CA
    Correct. Luscious was using someone for repaired Combo Meters, but same outcome as the Doorman Combo Meters: repairs don't last. It may even be possible that Doorman gets theirs' from the same person as Luscious did.
    When your combo meter goes out, just get new.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Expensive advice.
    I'll look for lightly used if needed.
    CMs fail much less frequently than say, traction batteries, so unless different years require different versions the used market should be cheap.
    Addendum: These seem to be called 'cluster speedometer panels' on Ebay and run $100 - $150 for used. Compare that to the new cost, which IIRC is about $1000.
    Or check out Part My Ride
    #7 SageBrush, Jan 15, 2015
  8. 3prongpaul
    956
    735
    Only problem with used is odometer reading and VIN have to be entered somehow. Dorman and other rebuilders program the info into the unit before shipping.
  9. SageBrush
    11,627
    2,533
    Southwest Colorado
    Ah yes, thanks for the reminder Paul. I forgot those details because I have no intention of reselling the car.
    I thought the odometer reading can be an clerical change at the local DMV. No idea about the VIN.
    Do you know what Manufacturer years can be interchanged ?
    #9 SageBrush, Jan 15, 2015
  10. JC91006
    16,936
    8,647
    Since this is a known defect that carries a 9 year warranty, wouldn't it just make sense to tell the dealer it failed before the 9 years is up? It'll happen sooner or later, better take care of it before the 9 years is up
  11. bisco
    52,812
    it would be interesting to know the percentage of bad ones, but it's likely quite small, and i don't think they all fail eventually, but were only on year eleven.
  12. exstudent
    2,214
    905
    Torrance, CA
    NEW Combo Display, Part# 8329147360, is $266.54 at Camelback. Rebuilt on eBay is $149. Small difference of $117.54; I'd go new b/c better chance of lasting as long as the original one that died. This would be a small selling advantage, should you sell your car private party later.
    Maybe try selling your dead Combo Meter to one of these repair people for a few dollars. This would make the $117.54 difference just a little bit smaller.
    SageBrush likes this.
  13. exstudent
    2,214
    905
    Torrance, CA
    I'm sure some dealers who like easy $, will take customers word that it happened.
    Other dealers may push back that this intermittent problem needs to be observed.
    Don't know how dealers would respond if one had cell ph video evidence of the combo meter not working?
    Wonder if Toyot treats this like HMO's:
    1) always deny unless evident in presence of service writer.
    2) allow if customer makes a big stink
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    Right you are -- quite a bit less than the $1000 I remembered.
    Seems that one h/w version is up to 11/2005 and the next version until 1/2007. Don't know what happens later.
  15. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Would this new one from Camelback still have to be "flashed" with the information that Paul mentioned above? Would Camelback do that before shipping? If not, I wonder if a local dealer would even do it, and if so, what they would charge. I presume this is not something one could do with Techstream.
  16. exstudent
    2,214
    905
    Torrance, CA
    Good question. Call/email them to know for sure.
    I'm sure all dealers can program this and probably charge for it. Doubtful programming is included w/ purchase price.
    Only dealers have the programming ability b/c of fraud. Evil people would be rolling back the odometer w/ techstream.
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    You could say the same thing about key duplication.
  18. JC91006
    16,936
    8,647
    The TSB states the dealer has to take your word for it, it doesn't have to malfunction in their presence.
  19. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...let me know what you do on your 2006....I got til mid-Sept
  20. JC91006
    16,936
    8,647
    I have til august
