Anyone else is running K&N filter in GenIII?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cyclopathic, Apr 22, 2011.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Can you describe the method you used to reach this conclusion?
  2. Zoom Zoom
    Zoom Zoom New Member
    Sacramento California
    I am also running a K & N air filter on my Gen III and do notice a difference in the performance of my Prius. It has also improved the MPG that I am getting by 2 to 3 miles per gallon. :D
  3. shawnsprius
    shawnsprius Junior Member
    84
    South East
    Brilliant!
  4. movingforward
    movingforward Member
    169
    The Great White North
    So crap, after this heated debate, it seems like we have no definitive conclusion?! The performance I'm trying to achieve is better mpg and by allowing more O2 to get into the ICE should allow better combustion due to a better air to fuel mix ratio and therefore better MPG?
    What kind of dirt or dust particle are we talking about that could create a catastrophic engine failure? In a turbo car, I wouldn't take a chance but in our Gen3 Prius, it makes sense to me. I was hoping for more instantaneous throttle response, reduce rubber trim-paper-metal mesh at landfill and a gain in MPG.
    So consensus sounds like to me is that K&N work fine, just don't oil the crap out of it and on both sides (only the outside of the filter) and only oil it lightly don't soak the dam thing after cleaning, don't expect your Prius to again 1000HP after installing this filter, and don't expect a gain of 100,000,000MPG improvement in fuel economy?
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Go pull out your clean oem filter and run it around the block and on the freeway. That will simulate max flow. If you like it then try out a k&n. Don't expect miracles. I ran with and without the filter at the track and didn't observe any changes.
  6. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    lets assume they perform the same. Has anyone done the lifetime cost of replacing normal filters verses oiling costs of the lifetime K&N?
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The K&Nwould be cheaper. :)
  8. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    And cause problems with your MAF sensor and other sensors because of the oil.
    Horsepower increase ??? You're imagining things. If it was that easy to give the car more horsepower, Toyota and all the other manufacturers would have done it decades ago.
    REV
  9. stripedrex
    stripedrex Junior Member
    29
    Smithtown, NY
    Not really, manufacturers try to balance comfort, cost and performance. You notice people mention increased noise which may contradict product goals especially if they hit their performance and emissions goals. Also paper is cheap, more advanced filters cost more $. I personally prefer amsoil ea filters which require no oil (which injen seems to partner w). Not all cars benefit aftermarket intakes. Some cars do maybe toyota purposefully made the intake restrictive for emissions reasons which is why people see a difference? Dyno is the right way to Determine this and injen claims to have dynoed it. Hopefully ill have some extra cash to dyno test. Need to wait for a dyno day somewhere. Lol I need a prius first =p.
    Samsung Epic ?.
  10. movingforward
    169
    Well...looks like the jury's out on this one. Both sides have their valid points. I'll call it a tie for now.
  11. stripedrex
    29
    Smithtown, NY
    Haha there's no winner until this dyno tested and we have long term results =). You can even prove mpg in a controlled test. Like cruise control same speed for a distance same day, same car, same road and see what it averages =p. We can prob think of a better test.
    Oh also the cel is prob more o2 then expected and not oil. K&n comes properly oiled ootb and people who mess up are the ones that use the cleaning kit. Again I like amsoil > k&n for that reason. More tech lower risk and easier to clean.
    Samsung Epic ?.
  12. justana
    justana Junior Member
    60
    :cheer2:
  13. movingforward
    169
    I'm starting to lean towards the Amsoil Ea filters now after reading all the controversies...
  14. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    Too bad they are not available for our cars.
  15. revhigh
    986
    141
    So .... are you supposed to send the K&N back to the factory to be cleaned and oiled ?? I'd venture that almost every person using the K&N is going to clean and oil it themselves. Also, I referred to MAF problems due to the oil from the filter, which can RESULT in CEL issues. They don't cause the CEL directly, they damage or contaminate the MAF sensor, which then triggers a CEL.
    THe Toyota factory filter or an equivalent replacement is the one to use if you don't want to risk problems. I change mine twice as often as factory recommended ... in other words ... every 15,000 miles.
    REV
  16. RandomLurker
    RandomLurker Junior Member
    No Prius, yet, but we do use K&N air filters on the car, truck and bike. All fuel injected. The bike even has a Cobra fuel manager. Not that it would be damaged by an oiled filter, just saying that I use a K&N air filter in a fuel injected vehicle that I make fuel:air adjustments to. So there's one that can be maximized to take full advantage of any increased air flow.
    My own butt in the seat opinion is that the claims of increased horsepower, fuel mileage and any other selling points of K&N 'performance enhancements' are overstated.
    It is still a good filter. We've used them for 10s of thousands of miles now and have not had a problem from them. Nothing fouled from oil and our air boxes don't look like sand boxes. Follow the directions for cleaning and oiling and they are fine.
  17. burnerx
    burnerx New Member
    32
    I just installed K&N filter... definitely did not take away the delay ....
  18. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I tried K&N (and similar) air filters in a few vehicles. Results were:
    - Increased intake noise (sometimes a good thing)
    - No performance or MPG improvement beyond a normal air filter change
    - Evidence of more dust getting past the filter, especially since we have many dirt roads
    - One vehicle cooked a mass airflow sensor.
    I grew up and now stick with factory intakes and filters.
  19. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    earlier in the thread there is a link to analysis K&N did, and they found no evidence that the MAF sensor failure was caused by filter. Go read it it was done by independent lab IIRC.
    with respect to HP increase the difference negligible when compared to new OEM filter, but could be 2-7% when OEM filter is clogged.
    with respect to dust yes filter will let more in engine, but the only study I've seen on was done on large stationary diesels. Use of oiled gaze filters shorten rebuild cycles from 22,000hr to 18,000hr, about 20%.
    at avg speed 35MPH 20,000hr will be 700,000mi. Also the study was done on mining equipment, which operates in worse possible dust conditions.
  20. cyclopathic
    3,292
    547
    2014 Prius c
    how many miles on OEM filter? perhaps the difference mine had 30K when it got replaced.
