Anyone else notice EV power is greater than ECO?
Discussion in 'Prime Main Forum (2017-2022)' started by chenderson2, Feb 7, 2018.
  1. chenderson2
    chenderson2 Member
    94
    57
    Houston
    When driving with the electric motor only I notice it has more pep than when using the gasoline engine. It is most noticeable as the charge goes to zero and the cars switched to gasoline power. The car feels like a heavy load has suddenly been placed on it.
    ggalanti likes this.
  2. benagi
    benagi Active Member
    525
    280
    Utah
    All the Primes are that way. It took me some getting use to but now I know what to expect. You sure take a hit on the eco scores when the ice kicks in. Enjoy the ride. I sure am.
  3. Tideland Prius
    16,211
    It's similar in the Volt. i test drove the Gen 1 Volt back in ... 2011? It was really peppy in EV mode but once I switched to Mountain Mode, it drove like a Prius.
  4. padroo
    padroo Senior Member
    2,763
    2,251
    This is just a guess but electric motors can build torque instantly but gasoline engines build torque with time after the engine starts.
    Mark57, bwilson4web and benagi like this.
  5. DavidA
    2,329
    1,812
    Chicago western burbs
    My Prime in EV + ECO mode seems to have more kick than HV gas + Normal mode.
  6. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    I believe what you're seeing is due to poor mapping of torque curves and throttle response between ev, ev+ice, and ev+ice (warmup).
    it seems fairly smooth to me when the ice kicks in AFTER it has warmed up (that is, you're driving in hv mode with a warmed up engine and the ice kicks in and out, it feels rather smooth), however when the ice is in warmup and the car is trying to limit the power a cold engine is outputting it certainly feels like you're missing something...
    It feels like they have the ev and ev+ice throttle mappings done nicely, but that the cold-ice safety is a downstream effect after the mapping is done and that is causing the irregularity. Or it could be something to do with mg1 no longer being available as a motor after the ice is running (only as a generator?).
    Not sure, but there is definitely a poor feel when it's going into ice warmup. When it happens I always let off the gas and reapply to get back into some sort of sane mapping point.
    heiwa likes this.
  7. bisco
    49,816
    pip is the same way, engine driving is a drag.
  8. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    heiwa likes this.
  9. zigzag
    zigzag New Member
    Basingstoke, UK
    2017 Prius PHV
    Excel
    I've only had my Prius just over a week. I noticed this effect and it generally happens at an awkward spot on my journey to work each morning. There is a steep hill where I can suddenly find myself holding up a line of traffic. I have now started turning EV mode off just before that point so that the engine is warmed up befor and that seem to work much better. It does however seem to knock my points down a bit on the display. Last week I scored 85/100 for the journey by the end of the week but this morning using that technique I only scored 55/100.
  10. FuelMiser
    FuelMiser Senior Member
    1,306
    892
    Monument, CO
    What you're feeling is torque, and electric motors supply full torque from zero RPM. Gas engines build torque gradually from idle.
  11. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    warm up cyclitus
    vvillovv likes this.
