Anyone else the $99 Ebay front lip installed on their cars?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by D Unit, Nov 21, 2013.
  1. Jessemkane
    Jessemkane Member
    44
    111
    Illinois
    I wouldn't even call it a modification. The lip fits real tight side to side, otherwise every tab on the lip lines up directly with the factory mounting tabs on the front bumper. I didn't need a heat gun or anything else either. I mounted one side of the lip while a buddy held the other side in place, then moved around and mounted that side. From there its just drilling the holes into the tabs on the lip for the factory bolts to go through and using the supplied self tapping screws to pull the lip tight to the bumper where ever it is loose.
    There was no cutting or trimming or custom molding involved. Yes it is a tight fit and you have to tug it a bit to get it around the bumper, but no major modifications are needed.
  2. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    I think you just sold me on getting one after this description, lol
  3. GeorgeM269
    GeorgeM269 Member
    Panama City, Panama
    Hahahaha welcome onboard
    HelloHybrid likes this.
  4. Zipsta
    Zipsta Member
    35
    39
    Inland Empire
    I'm gonna have to second HelloHybrid. I'm getting one too. It's a steal for 99 bucks. Can you post the link? Or is it the link that's listed on the earlier posts?
    Z.
  5. GeorgeM269
    GeorgeM269 Member
    Panama City, Panama
  6. Zipsta
    Zipsta Member
    35
    39
    Inland Empire
  7. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Car looking real nice! I like the duracell hybrid color combo.
    Accordlayingkit and Jessemkane like this.
  8. Jessemkane
    Jessemkane Member
    44
    111
    Illinois
  9. Zipsta
    Zipsta Member
    35
    39
    Inland Empire
  10. HelloHybrid
    482
    1,483
    For anyone on the fence, you can use promo code CMOTORSMAY16 and get an instant $20 off. I just ordered one... page says only 30% of inventory left.
    EDIT: I guess YMMV. Some people are saying the code didn't work for them.
    #110 HelloHybrid, May 11, 2016
  11. RollinBad
    RollinBad Member
    46
    72
    Oside, CA
    Mine actually didn't come with any screws... Anyone have a pic of what the screws look like? Or maybe I can use 3M tape...
  12. GeorgeM269
    GeorgeM269 Member
    Panama City, Panama
    The screws on mine looked like this one:
    Although a bit shorter.. But hope you get an idea.
  13. RollinBad
    RollinBad Member
    46
    72
    Oside, CA
    Awesome thanks!
  14. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Thanks, HelloHybrid.. the $99 lip has been in my cart for ages.. but that $20 off sealed the deal.. thanks!
  15. HelloHybrid
    482
    1,483
    Joined the eBay lip club. It's not perfectly seamless on a 2012-2015 Prius, but it still looks really good for $100.
    PriiPrii, Lit Lit, Xterra72 and 8 others like this.
  16. StarCaller
    StarCaller Senior Member
    1,255
    704
    Cedar Crest, NM, USA
    how did it fit?
    did you have to jury rig a lot of things?
  17. HelloHybrid
    482
    1,483
    Nope, everything is really straight forward. I was able to install it solo as well. @Jessemkane mentioned his was a tight fit on the sides, but I didn't experience that. The biggest pain is just drilling the mounting holes, especially the ones for the plastic clips on the side of the bumper, near the tires. This was my process:
    1. Drill holes into lip tabs. I just guessed where the visual center of each tab was. I didn't do this, but might want to put 3M double-sided tape on the sides of the lip where they'll make the most contact with the bumper.
    2. Remove splash guard screws towards the front of the car. I remember there being 5.
    3. Remove plastic retaining clips on the sides of the lower bumper, near the front tires.
    4. Insert the lip in between the bumper and splash guard, and in between the 2 pieces where the plastic clips go. The lip should be held up off the ground at this point.
    5. Reinstall the splash guard screws.
    6. This step was kinda improvised as I went. I didn't have the holes drilled on the sides of the lip for the plastic clips to go through, because I had no idea where to drill them when the lip was off the car. I jacked the car up high enough to fit a screwdriver underneath and drilled the holes into the lip while everything was lined up. Reinsert the plastic clips.
    7. The front of the lip will still have a lot of play and wiggle since the curved part won't be sitting against the bumper, but rather underneath it. The lip comes with self-tapping screws. Use these along the front section of the lip to to secure it to the bumper. Jesse mentioned he used nuts and bolts instead of the self-tapping screws. If I remove the lip to paint it, I'll go this route as well since the threads probably won't hold anymore. This would be a little more involved since you'd need to completely remove the splash guard and have enough room to bend your arm to reach into the front of the bumper to drop the bolts in.
    #117 HelloHybrid, Jun 1, 2016
  18. Lit Lit
    Lit Lit Active Member
    104
    340
    Northern California
    What size are those screws?
    iPhone ?
  19. Lit Lit
    104
    340
    Northern California
    I jumped on that eBay lip for $99 not a bad set up
    iPhone ?
  20. Johnsk93
    Johnsk93 Senior Member
    212
    1,055
    San Jose, CA
