Anyone end up with noisy tires after long overdue rotation?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by MannySwol, Nov 14, 2016.
  1. MannySwol
    MannySwol Junior Member
    30
    Noticed front tires were getting wore out.. about 3/32" left, so I ordered 4 tires.
    When the tires came, I checked out the rears.. they actually had about 6/32" left and looked good, so I decided to only replace two and keep the other two on hand.
    The car saw normal rotations until 25K... but car is at 54K now. My last car, a Honda Civic wore out tires almost evenly and I never rotated.... I hadn't realized this car chews up the fronts as badly as it did until now.
    Tire place insisted putting new tires on rear and moving rears to front. Wife suggested the rear of the car felt light on wet roads, so I agreed.
    Now, I've got some tire noise on the fronts. It's not super loud, but obnoxious... seems to be even left and right. Some threads in other forums I found describe it as a "helicopter noise" others a "wa-wa-wa". The only thing I "feel" is the noise resonating.. the steering wheel doesn't move or vibrate.. car still tracks straight. My gut instinct was right (I think), the rears obviously wear differently based on the differing tread amount.. and I imagine some camber differences as well.
    Has anyone experienced this? I'm debating rotating them back to the rear... but if I can expect it to subside, I'll just live with it.
    #1 MannySwol, Nov 14, 2016
  2. MannySwol
    30
    I can't believe this got no replies.
    Anyway, I gave it about 1800 miles and ended up putting the old tires back on the rear and the newer tires back on the front.
    This solved about 90% of the noise issue. Feels like driving a new car again. Good enough for me.
    49,507
    sorry man, never saw it. at 54k, i would think they'd get noisy anyway. at 48k, mine were horrible, but still plenty of tread. couldn't stand the noise anymore, so i put new sneakers on. i'm not fussy about rotating.
  4. MannySwol
    30
    I don't do the rotations unless I'm in for a service and it is free. I typically do all work myself and it is a pain to rotate.
    This car though, man it chewed through the fronts. I bet I can get another 20K out of the originals with them on the rear.
  5. bisco
    49,507
    maybe so, but i wouldn't call 54k chewing through them. especially oem's, which are designed for mpg's and not long wearing.
  6. MannySwol
    30
    Compared to the rear tires is what I meant... A relative comparison.
    But yes, I agree. Even 54K while neglecting rotations isn't bad at all for OEM.
  7. bisco
    49,507
    what did you replace them with?
  8. MannySwol
    30
    Yokohama Avid Ascend
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Has anybody else noticed that Goodyear Fuel Max tires get VERY noisy after they are about 1/2 way worn out. Yorkahamma tires seem much better
