Anyone gotten GPS coordinates from onboard nav?
Discussion in 'Gen 2 Prius Audio and Electronics' started by electricitylikesme, May 6, 2008.
  1. electricitylikesme
    electricitylikesme New Member
    40
    Has anyone here had a crack at pulling the GPS coordinates from the factory navigation system?
    Based on everything I've read, I'm fairly sure they don't get output on any of the in-car networks however I've been led to believe that there may be some contactable points inside the nav unit where a serial data stream from the GPS chipset can be extracted.
    Has anyone tried this? Does anyone know what trace I might find the data from, and is it really just a serial data stream (i.e. can I put it through a MAX232 level changer and send it into my car PC for purposes I don't know yet)?
  2. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    I'm not even sure what you just asked. Wish I could help.
    Are you talking about downloading a track log, or such? Or downloading saved waypoint co-ordinates for computer display use?
  3. electricitylikesme
    40
    Basically has anyone taken the cover off the nav system and had a look at what GPS chipset it uses? Or, even better, experimented with directly accessing the data pins on the chipset?
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    I haven't opened the nav unit, but you can get latitude and longitude from the screen visually.
  5. eclipse3g
    eclipse3g Junior Member
    63
    Is the GPS elevation readout available on the MFD?
  6. 9G-man
    1,273
    194
    Atlanta, GA
    no
