Anyone has a Serivce Manual for Timing Chain?
Discussion in 'Gen 3 Prius Technical Discussion' started by KeKeKeKeViN, Apr 25, 2017.
  1. KeKeKeKeViN
    KeKeKeKeViN Junior Member
    Sacramento, California
    Hi. Folks.
    I'm currently in the process of changing the head gasket on my 2013 Prius V with 190k miles because it has the typical scary rattling noise on start up and red light stop. Has a misfire code on cylinder 1. Piston 1 & 2 are wet. Coolant level has been droping like crazy.
    Anyways. After I removed the timing chain tensioner and timing cover. I just realized I forgot to put it back to TDC and mark the timing marks.
    Well. While I'm not new on rebuilding Engine as I work on my race car(Honda K-series) all the time, I wanna make sure I do it right. I search online and found nothing about the timing marks for the Gen3 Prius. Maybe it's still new at the moment. Well if someone has the service manual. Please help me. WIlling to pay(via PayPal)
    Thanks,
  2. ChapmanF
    18,996
    There are three special-color links built into the chain at the timing mark positions for crank and both cam sprockets. They'll only be at the right positions every n revolutions (can work out n from number of chain links, sprocket teeth, and a little number theory) but if you don't see the two up above the cam sprockets and you can spin the crank some multiple of 2 revs until you do, you should be in business.
    -Chap
  3. Former Member 68813
    3,524
    983
    US
    Off topic, but what condition was the EGR system?. I have this theory that plugged EGR contributes to HG problems.
    Aaron Vitolins and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    In a similar vein, did your prius consume any oil?
    You doin any pics while you go?
    Keep us posted (y).
  5. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
  6. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Yea , I lucked out,
    was setting TDC and after 3 turns of crank hit that sweet spot...
    #6 Tbkilb01, Dec 6, 2018
