Anyone have AC compressor fail at 2 yrs/45k?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Lore56, Jun 29, 2014.
  1. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    Congratulations!! another dealer working with Toyota & doing the right thing.
    This should make the rest of your vacation a little more enjoyable - yeaa!!
  2. Okinawa
    Okinawa Senior Member
    1,333
    320
    I think Toyotas and the Toyota Company are great. I just bought my 5th new Toyota. They sure took care of you. That had to be a big relief for you.
  3. orenji
    orenji Senior Member
    5,887
    3,490
    Thank you Toyota, this is what I have come to expect from the #1 car company in the world. This is why I have owned a Celica, MR2, Yaris, Lexus and Prius! All great cars. Toyota customer service is becoming Lexus customer service, no one compares to Lexus! :)
    #23 orenji, Jul 1, 2014
  4. ibmoses
    ibmoses Junior Member
    109
    22
    Excellent news.
  5. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    I am curious, did your AC start making any weird noises that you noticed? I, too, am at almost 2 years and am at 46k miles. My AC is making a noise like there are marbles in the compressor. However, it is still working. I was just wondering if you heard this noise also (more noticeable from outside the car).
  6. MPGMachine
    MPGMachine Junior Member
    30
    Los Angeles
    Hope the same things happen for me. The AC on our 2012 just went out. No check engine or any other light is on.
  7. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Good luck! If you leaked out the refrigerant then the system just won't come on. Remember, only electrical problems set codes. That is, any item directly or indirectly related to wiring. The ac comp is an electric motor so if it were to lock up, I think it would sense current and set a code.
  8. qdllc
    qdllc Senior Member
    1,377
    400
    I find two warning signs common to a failing A/C system.
    1. Ineffective cooling. For safety, you should have an A/C system checked every 2 years or so by someone who can just "top off" the system if it reads low. ALL A/C SYSTEMS LOOSE REFRIGERANT OVER TIME. It should be over 5 years before any measurable deficiency is found, but if you are losing refrigerant too much in a short time, there is a leak somewhere. So long as your system doesn't run low/dry, you should have no compressor wear. Low refrigerant makes the compressor work harder to do the job, and THAT is what makes it burn out over time. You will see this easily in any A/C system too small to do the job it's tasked with. The on/off cycle of the system allows the compressor to release excess heat that builds up inside of it. Constant running overheats the component.
    2. Noise that wasn't there from day one. A compressor is a relatively silent part of the A/C system. You hear it running, but there is not mechanical sound (grinding, pinging, clanking, etc.) associated with it. If a sound emerges, SOMETHING IS WRONG. If you are lucky, it's just a squeaky belt, but if it makes noise when the clutch engages the compressor (belt driven compressors) or it otherwise engages (not idle), and it didn't make this noise from the day you bought the car new, it is suffering from an internal flaw that WILL cause failure in time.
  9. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    The Prius compressor is quite noisy when you are outside the car. If you are concerned then get it checked by the dealer.
  10. trentofdestiny
    1,104
    227
    Harrisburg, PA
    This is true however the new compressor seems quieter than the fans now, which the normal hum was much louder before. It seems like it's not working as hard now. :)
  11. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    No belt or clutch on the Prius a/c. Compressor is driven by a variable speed electric motor IIRC.
  12. Mendel Leisk
    42,368
    The OP's predicament seem akin to the situation where you're threatened with something catastrophic, then it's deescilated, and you're expected to be greatful. Six grand for AC repair smacks of poor engineering AND gouging.
  13. qdllc
    qdllc Senior Member
    1,377
    400
    True, but the rule is the same. If you hear noise when it's running that wasn't there from day one (and even then, it's not that noisy), it's an indicator of trouble.
  14. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    No A/C problems with 60k on my 2010.
