Anyone have experience with tire repair kit?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by MitchR, Oct 7, 2016.
  1. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    RCO and Prodigyplace like this.
  2. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    It was snipped as close as I could get it, and probably wasn't even touching the road most of the time.
    I have four tires that are round and hold air now, I'm happy.
    Kurt Weiske, krmcg, RCO and 2 others like this.
  3. Kurt Weiske
    Kurt Weiske Active Member
    178
    131
    I *hate* that when they leave the plug sticking out above the tread! Conscientious mechanics will trim the plug flush with the tread using a single-edge razor...
    RCO likes this.
  4. Mendel Leisk
    41,460
    Tough ones will use a double edged razor. :ROFLMAO:
    Sorry sorry...
    Robert Holt, RCO, krmcg and 1 other person like this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Or a samurai sword :cautious:
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
  7. Mendel Leisk
    41,460
    Straight razor would be ideal!
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I think you got your hat-trick on that post
  9. Prodigyplace
    12,563
    11,779
    Central Virginia
    At least in hockey, a hat-trick is 3 goals in a single game. I only see 2.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I believe one has now been deleted! (y)
    Prodigyplace and Raytheeagle like this.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
  12. Prodigyplace
    12,563
    11,779
    Central Virginia
    Don’t worry. Just an off-topic rabbit trail.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    When I first opened this thread, kithmo's post was repeated twice more (hence my hat-trick comment), but when I came back later to read pp's reply, the number of repeats had reduced to one. (y)(n)
    kithmo and Prodigyplace like this.
  14. shugo
    shugo Junior Member
    Venice, CA
    2014 Prius Plug-in
    I had a completely flat tire today. I thought I'd give the Toyota issued inflator and sealant without any directions--typical behavior on my part. Once I figured out how to connect the two, I hooked up the hose to the valve and plugged in the pump. Turning it on it slowly drains the jug of sealant into the tire. And, lo and behold, the tire began to inflate. It took a long time and I could hear the air hissing out of the nail-hole at the top of the tire at the eleven o'clock position (the valve was down at the five o'clock position). I got it to probably about 25 psi and drove away. I figured, not unlike a bicycle, the sealant works it's way into the hole once you start driving. I drove to closest tire service center and topped off the tire with air. There wasn't anymore sealant seeping out although the inside of my wheel well was coated with white sealant. I got home and it stayed inflated the whole way.
    I'm hoping the hi-tech valve didn't get destroyed by the goop, and I'm exploring new tires now... But, it worked. The gizmo and goop worked. I was really surprised.
    RCO and krmcg like this.
  15. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    You need to look at the instructions in the Manual - it's a several step process. Only 18 pages - but critical for safety. It includes many safety instructions including " upload_2019-3-14_17-41-16.png ".
    Don't drive for long before repairing it.
    " upload_2019-3-14_17-42-32.png "
    RCO likes this.
  16. Prodigyplace
    12,563
    11,779
    Central Virginia
    There may be differences between the PiP & the Gen 4, but most of the warnings should apply.
    alanclarkeau likes this.
  17. alanclarkeau
    7,045
    7,592
    Sorry, I didn't realise you had an older car - did you check the expiry date of the sealant?
    Re the TPMS - the Gen 4 Manual says "After use of liquid sealant, make sure to replace the tire pressure warning valve and transmitter when repairing or replacing the tire"
    Prodigyplace likes this.
  18. Mendel Leisk
    41,460
    @shugo If the puncture on your tire was just a nail in the tread, a simple plug-repair would very likely have fixed things, permanently: the tire could continue to be used, and no gummed up rim and TPMS sensor.
    I've done a couple of plug repairs, about 6 years back now I think. One of the tires (a snow tire) is on the car right now, and the other (one of the OEM all-seasons), I just retired due to age.
    For your scenario, without a temp spare, you need a plug repair kit, and some method of airing up the tire after. Even a bicycle pump will do, in a pinch.
    RCO likes this.
  19. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I got a nail in my tire two years ago. I had a 12V pump and a Blackjack tire plug kit. It took about half an hour — the puncture was hard to find. But the plug lasted over 40,000 miles, until I replaced all the tires with a new set. That’s way less trouble and expense than using tire glue.
    RCO, Mendel Leisk and alanclarkeau like this.
  20. Mendel Leisk
    41,460
    Yeah was taking off the snow tires yesterday, and I like to roll them along, pry the gravel out of the tread*, which simultaneously serves as a puncture inspection. One tire has what looks like a chewing gum remnant: the plug repair, from about 6 years back.
    * Wear safety glasses when doing this, to protect your eyes, and/or your glasses.
    RCO likes this.
