Anyone have frame rust
Discussion in 'Gen 3 Prius Technical Discussion' started by heyphillip, Dec 26, 2018.
  1. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    Notice my 2010 has some issues with frame rust in the front of the car not surprised considering the vehicle was mainly since new upstate NY than was auctioned in NJ I've never heard of Priuses having frame rust issues
  2. Mendel Leisk
    42,293
    @tvpierce suggested boiled linseed oil as a protectorant. I brushed some on last spring and it's held up pretty good. Used sponge brushes, works pretty good.
    I recall 2~3 years back having a what-the-heck moment, looking at the rear suspension in particular. It's hopelessly vulnerable to rusting, seems to have one token coat of black paint over raw steel. The bolts rust-bloom very fast, ditto for the rear cross beam, the trailing links and what have you. The welds in particular rust up fast.
    To really get at the trailing links you need to take off some plastic panels. If you're lucky you'll be able to back out the bolts holding those rusted up pieces of junk before they're complete rust lumps, and the heads snap off. Just drench them in some oil before reinstalling, ditto for any bolts and screws.
    It's best to take the wheels off for better access.
    The front is a similar story, maybe not quite as bad though.
    Oh, and I'm not even in the snow belt, lol.
    #2 Mendel Leisk, Dec 26, 2018
    Georgina Rudkus likes this.
    52,803
    no idea, have never looked underneath. i suppose i'll have to when someone reports a part rusting through...
    Raytheeagle likes this.
  4. padroo
    padroo Senior Member
    2,763
    2,253
    When I read you post I immediately thought of upstete New York. My 2008 was the only one I ever saw with heavy rust on the right rear rocker panel at 100,000. I drove it in a highly corrosive environment year round.
  5. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    Never again will I purchase another Prius in that area N.Y. Connecticut ,Canada I will drive this one until it falls apart then I'll get another Prius
    Raytheeagle and bisco like this.
  6. bisco
    52,803
    how many miles on her? there's more to worry about than surface rust
  7. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    105,061 thousand
  8. bisco
    52,803
    time to clean your egr circuit (y)
  9. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    I had it gone over a week ago by Team Toyota out of Princeton NJ they gave me a report on leaking oil from seal where the timing chain cover is 1,250 dollar repair job(won't get done) corroded rotted Struts 698 dollars to get new ones so there's all the issues I have another vehicle a 2016 Toyota Tacoma so I'm not spending money on this car I only payed 7500 for
  10. bisco
    52,803
    i remember that, but what about the egr circuit?
  11. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Frame rust is usually NOT a problem.
    Rust/corrosion on other active parts might become a problem but the frame is thick enough to last a LONG time.......unless it is damaged.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    My old man uses old motor oil underneath the car for rust protection and he lives in northeastern Pennsylvania where salt is their solution to slick roads:cool:.
    Has worked well at saving his vehicles for the last 30 or so years;).
    Best to start treating it now before it gets worse(y).
  13. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Mine has a rust issue in a weird place. I have a rust problem on the door sill on the drivers door. I have to get it fixed about every two years.
    It only appears around and under the plastic Prius emblem plate. So far it is only light surface rust but no matter what product the body shop uses on it the rust comes back in a year or two.
  14. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    Is that a EGR cleaning?
  15. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    ALS likes this.
  16. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,568
    2,602
    Taylors, SC
    Uninform "bliss." If if it looks good on the outside, the inside must be just as wonderful. That's why cars with terrible reliability continue to sell; sometimes better than the mundane and reliable ones.
  17. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Is that all? Minor bubbling of paint on the lower part of the body on 8 years old car driven in northeast winters is perfectly normal, IMHO. Given enough years, the road salts corrode any makes and models, whether it is $4,000 used Prius or $40,000 luxury car purchased new.
    #17 Salamander_King, Dec 27, 2018
  18. bisco
    52,803
    that's one part. you can find the whole procedure in a NutzAboutBolts video
  19. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Yep the exact same spot. Dealers body shop said my Prius is the only one they have seen rusting in that spot.
  20. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    Some of my rusted areas 20181227_133632.jpeg 20181227_133512.jpeg 20181227_132939.jpeg
