Anyone have one yet?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by coach81, Feb 25, 2012.
  1. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    Just the morning trip. Yep, no charging at work. Do you know what screen shows the ratio. I was flipping thru the different trip meter settings to get the numbers I gave. Do you mean the screen when you turn off the car?
  2. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    Lurk! You actually drove it home in eco mode?! OMG I gotta hand it to you. I would have been way too excited to test the modes out.. and certainly not the ECO!
    :: applause ::
  3. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    Max MPG, baby....and HOV stickers, of course! :D
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Yeah, I ran ECO mode for a while on my 2010 but it is simply too sluggish. Normal works fine for me and my MPGs aren't any different. YMMV...
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    This is from Owner's Manual page 271 and 272. It looks like you press the TRIP button.
  6. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    Trip A (this morning) 4.8 mi EV avail, 25.7 mi Cons: 73mpg Ave 28mph
    Trip B (all) 65.2 mi Cons: 48mpg Ave 17mph (gotta love LA traffic :( )
    EV 10% 7 mi 0Kwh HV 90% 58mi 1G
    2 people like this.
  7. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I'm a little surprised that you have 4.8 mi EV avail on 25.7 mi trip. Did you switch to HV mode or did it regenerate that much EV range or something else?
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Is that for Trip B (lifetime)?
    What about the ratio for Trip A? That's the important one since you started with a full charge.
  9. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    The car came without any charge, so Trip A was the start of the charge. Trip B is lifetime.
    Yesterday's trip was a mixture of HV and ECO, no EV at all.
  10. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    I had 4.8 mi EV avail because I chose not to use EV until it ran out. I plan on using the remainder on the trip home tonight.
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Ok, you drove 7 miles on EV so far. That must be from this morning. So 25.7 miles - 7 miles = 18.7 miles on HV.
    That's like 27% EV and 73% HV for this morning trip. You still have 4.8 miles left so we'll see how it goes on your way home. Make sure you use it all up! :)
    I am concern that kWh is saying 0. I thought it should not be 0 kWh since you put 7 EV miles already.
  12. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I hope the 48 an anomaly. 48 MPG + kWhr ... no way.
  13. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Thats some serious efficiency. I bet the Volt can't do that. :D
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Much of this lifted from F8L's v thread ... anything else important to add / subtract for 'MPG' stats?
    Year of vehicle:
    Date:
    Miles driven:
    Gallons Pumped:
    Calculated MPG:
    Displayed MPG:
    Electricity Consumption:
    EV ratio 1:
    EV ratio 2:
    HV%:
    Average Speed:
    Tire Size / Wheel size:
    Tire Brand / Model:
    Tire PSI (Front / Back):
    Conditions: (A/C usage and temp setting, etc)
    Commute Length:
    Hypermiling Techniques:
    Other: (this could explain why a tank was bad or good or other unusual conditions like a rain storm, new tires, lots of short trips, etc.)
  15. ClaySacramento
    ClaySacramento Junior Member
    58
    Sacramento, CA
    When Toyota officially introduced the 2012 Prius Plug-in Hybrid it was stated that it "will allow true EV operation and performance for up to 15 miles at speeds up to 62 mph." I expected the EPA rated blended gas/electric range to be less than 15 miles, but I'm wondering what conditions are needed to get the trip computer to show the 15 mile range.
    Has anyone who received their car been able to travel close to 15 miles in EV mode when driving under ideal conditions?
  16. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I remember Toyota saying in September that the computer will learn from past trips and better estimate EV distance over time.
  17. hill
    9,013
    dang mark, if I'd known, I'd have mentioned pEEf. You know he mod's the portable charge cable (that comes with the car) with different hardware and a switching power supply so that the EVSE can charge off 120v - 208v or 240v. Very slick ... L1 or L2 from the same device. I know he's usually VERY busy, but if you pm him, he may want to put up a sticky (with the help of the mod's) on PC to that fact. I mean heck, I wouldn't have bought MY EVSE if I'd have known his mod was about to be released. And I'm SURE others would rather spend just a couple hundred for the mod, rather than maybe $2,000 for the hardwired jobbles like you & I have. Just a thought.
  18. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    What's the state of charge of the EV battery when it came off the ship? And what was was it when it left the factory? Two short EV's on and off the ship and at port plus 3 to 6 weeks self discharge equals how much used capacity? This is what the computer is initially seeing as EV range?
  19. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    Mine had no charge at all at pickup. Pushing the EV button returned an error stating that there wasn't any charge available.
  20. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    You have a running MPG average on your trip B, right? Lot of talk from all about EV range, but that average is going to be important, right?
    Sorry to be so blunt, but can hardly wait to see www.fuelly.com stats for the PiP.
    10/11 Pri about 47.x MPG, 2 Volts have 122 mpg and 2 others 66 mpg.
