Anyone headed to a You-Pull-It junk yard?
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Dec 6, 2023.
  1. JC91006
    16,936
    8,647
    If you’re going to a pick a part, can you check if there’s a JBL amp available for 2012 to 2014 prius? It’s under the passenger seat
  2. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    I think that is a very resonable explaination of how you use it, and smart.
    Why would you be worried about it?
    You can go to a fabric store, but some nylon strap as close to the size it is.
    Make your loop, then use some clothing glue to hold it together then use a sewing
    machine to keep it together. It doesn't need to be thick.
    I sew the straps on my seat cover if my dogs chew on them. Just use steady pulling
    pressure to help advance the strap and you won't brake a needle! Or two........
    Maybe try to find a braded metal strap. You can fold it in a loop and solder it together.
    Then solder the other end and drill a hold in it for the screw. ????
    Georgina Rudkus likes this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,604
    Taylors, SC
    The strap apparently tears apart at the stress point where the screw holds it to the panel.
    A larger fender washer might decrease the stress riser to a wider area to decrease the likelihood of the web ibg tearing apart at that point.
    Another method would be to grommet the hole.
  4. PriusCamper
    PriusCamper Senior Member
    13,468
    5,437
    Pacific Northwest, USA
    Maybe a strap off a Gucci purse would look nicer?
    Robert Holt likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    The Columbia Pull-a-Part is showing a 2008 and a 2011 in the yard inventory. Are there any other models that use that amp?
  6. JC91006
    16,936
    8,647
    That amount is hard to find, only in years 2012 to 2014
  7. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
  8. PriusCamper
    13,468
    5,437
    Looks like the post to which you refer was back in August. This is a good example of how lots of people can help you with an immediate solution on here unless you're way too particular and difficult, in which case the people trying to help will become annoyed, especially if you wait 4 months to ask the same question again expecting a different answer. Which in this case actually worked. He's got a free OEM one being mailed to him.
  9. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    bisco and PriusCamper like this.
  10. PriusCamper
    13,468
    5,437
    I'll never look at my box of scrap webbing & their related fasteners in the same way ever again because of you! :'-(
    Johnny Cakes likes this.
  11. Johnny Cakes
    1,065
    789
    Virginia, USA
    You rock! Check your PM.
  12. wr69
    wr69 Member
    143
    79
    portland, or
    How about just making one from webbing you can buy at Home BigBox stores? you can probably find a new screw to fit nicely too.
  13. Johnny Cakes
    1,065
    789
    Virginia, USA
    @TMR-JWAP sent me so many that I have cornered the East Coast market.
    wr69 likes this.
