Anyone install aftermarket HID's on their 2010 prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Rez90, Dec 20, 2010.
  1. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    6000K should have the blue tint along with less light output (versus 5K or 4300K)
    5000K is more of a pure white.
    4300K is warm white (a little yellow) but light output is highest.
  2. bagwell
    592
    49
    the woodlands, tx
    the install is pretty simple -
    remove stock bulb
    insert HID bulb
    hook OEM harness to ballast
    hook ballast to HID bulb
    if you are using a relay with direct wire to (+) and (-), these will hook-in only one way so you can't screw it up...only hard part is routing the wires.
