anyone know how to check aux battery voltage thru nav screen?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by minglee012, Apr 30, 2012.
  1. minglee012
    minglee012 New Member
    so cal
    I have seen on a few forums with a 2gen prius you can hold display button and switch headlights on off 3 times to get to diagnostic mode then hit display again and go through menu to look up aux battery voltage
    as seen here
    http: //priuschat. com/forums/gen-ii-prius-care-maintenance-troubleshooting/78412-entering-maintenance-mode-aka-12v-battery-check-without-switching-headlights-off. html
    any suggestions?
  2. jamesyouknowwho
    jamesyouknowwho New Member
    I had the same question and surprised no one knows the answer.
  3. TrafficMPG
    TrafficMPG Junior Member
    No nav here but I use the Scangauge for that amongst many other readings.
  4. fourenty
    fourenty Junior Member
    46
    25
    Endwell, NY (near Binghamton)
    Perhaps it is not possible.
