Anyone know how to fix Sunroof barriers?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ScudderWoods12, Mar 4, 2021.
  1. ScudderWoods12
    ScudderWoods12 Junior Member
    Snohomish Washington
    I saw this the other day and I am not sure if someone tried to break in or its wear and tear. Regardless, I want to fix it.
  2. addosso
    addosso New Member
    Sweden
    I don’t think someone has tried to break in. Is a normal defect for gen III sunroofs model! Mine has the same problem, after a while the rubber start to crack and break... unfortunately I read that the only way to get rid of that problem is to replace the whole glass roof :/ mine so far has no water infiltrations but I guess when it’ll have then I will arm myself with gaskets and a lot of patience... hopefully will work
    ScudderWoods12 likes this.
  3. Johnso1
    Johnso1 New Member
    Idaho
  4. Johnso1
    Johnso1 New Member
    Idaho
    Were you able to repair it successfully?
    I’m in that situation currently and it seems there must be a solution other than replacing the entire glass section! Can you offer advice?
Loading...
