Anyone know how to replace Blinker Relay?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by btped, Jun 21, 2018.
  1. btped
    btped Junior Member
    NY
    I have a 2006 Prius that has the blinker acting up. Sometimes the RT goes on and stays on without moving the blinker arm. I want to try replacing the Relay. Anyone know the process to remove the dash and get to the Blinker Relay?
    Any help appreciated.
    Thanks
    Bill
  2. Mendel Leisk
    42,242
    This might be what you need. Let me know if there's more to it.
    Petrodollar likes this.
  3. btped
    btped Junior Member
    NY
    Looking for more what I need to remove inside car to get to it. I've looked online and don't see any instruction for Flasher relay for the Gen 2 Prius.
  4. Mendel Leisk
    42,242
    Searching the Repair Manual, the expression "turn signal flasher assembly" only appears on the pages in the above attachment. Could it be that's all there is to it, a small block in the fuse box?
  5. btped
    btped Junior Member
    NY
    I think its above the left leg drivers area, above the fuses there. I don't know how to get to it. I've looked underneath and don't seem able to see it. I guess I have to remove the knee-dash panel to see if its accessible?
  6. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    Does this help?
  7. btped
    btped Junior Member
    NY
    That's the diagram I'm going off. That and when the blinker was on the sound was there. Just looking for any experience someone else might have had. I guess once I remove that dash panel I will see if its accessible?
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    This video is for replacing the combination meter, so it's overkill. But it will show you how to remove the dash. Just go as far as you need to to find the blinker relay.
    Petrodollar, Raytheeagle and ITBland like this.
  9. ITBland
    433
    278
    You only need the first ~40 sec of the video Jerry posted above. Pull off the silver air vent trim piece (VERY carefully! they get very brittle and will break easily--pull straight out, don't try to get the top and then the bottom, that will break the tabs or the piece itself--ask me how I know!) then two screws. Look for the yellow clips, they often stay in the rectangular holes in the dash. Be careful putting everything back together. In my used 2004, someone did not line up all the clips over their holes when pushing everything back together and bent the clips down (had to replace the entire piece with junkyard parts.) Don't worry about unclipping the hood release cable/lever from the trim, it should allow you to move it out of the way enough.
  10. Mendel Leisk
    42,242
    It's on this, Driver's Side Junction Box (don't you just love the copious use of abreviations...).
  11. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Looks like the relay is placed in the lower right corner:
  12. ITBland
    433
    278
    @btped , have you checked to see that all of the bulbs are working? If one of the bulbs on the right side burned out and then shorted, or the wires shorted, you might have weird problems like this. Put the emergency flashers on and make sure the bulbs have the same brightness left and right. --just a thought...:coffee:
  13. ITBland
    433
    278
    @btped , here is a great writeup on replacing the flasher relay: 2005 Prius LED Flasher Relay from very helpful user @kkeane.
    Also, here are the repair manual instructions for removing the instrument panel (shows all of the tabs.)
    SFO, Petrodollar and Mendel Leisk like this.
  14. btped
    btped Junior Member
    NY
    OK I changed the Relay. (Just a note: there is a metal plate with threw bolts that covers the Relay you need to remove, another :20 to take that off, then you have access to the Relay.) Pull out and replace with new Relay.
    Unfortunately the problem still exists.
    Its intermittent and driving me crazy. The local foreign car place could not discover the cause.
    At times when using the right blinker the left goes on as well(like its on Hazard mode) Other time the right blinker or both goes on for no reason while driving. Definitely makes for a less than safe condition.
    Any suggestion for the next item to check??
    Thanks
  15. Prodigyplace
    12,709
    11,847
    Central Virginia
    When it goes on while driving, does changing the steering wheel position stop that?
    Perhaps it is a weird clock spring issue. The clock spring connects the turn signal switch to the rest of the car, among other things.
  16. btped
    btped Junior Member
    NY
    Its basically as if the RIGHT blinker is always on. Even if I don't use the right turn signal switch.
  17. jerrymildred
    11,517
    14,164
    Tampa, FL
    I wondered about that. But the turn signal stalk doesn't turn with the wheel, so I don't think it could be the clock spring. But there must be a short between wires somewhere. Tracking it down might be a long process.
    padroo likes this.
  18. Prodigyplace
    12,709
    11,847
    Central Virginia
    Bad signal lever switch?
  19. ChapmanF
    18,942
    I had a bad feeling about that as soon as I saw you were writing about replacing that without more information to suggest it was the problem, but I'm sorry I didn't see the thread until now so it's too late to suggest anything else.
    If I'd seen it sooner, I would have suggested watching with Techstream to see what position the ECU tells you the signal stalk is in, and using the active tests to command the signals on and off and see what happens. Might at least narrow down whether there's an issue upstream or downstream of the ECU.
    -Chap
    SFO, jerrymildred and ITBland like this.
  20. UnitJuno1
    UnitJuno1 Junior Member
    Richmond, CA
    2023 Prius Prime
    SE
    Hi all!
    Does this work for 2015 prius too?
