Anyone know how to reprogram a Karr alarm system?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by phoenixgreg, Jun 1, 2013.
  1. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    My Prius came with a Karr alarm system and during a recent project, I touched what I thought was a ground wire to the chassis and now the Karr system will not accept the Prius remote's unlock button to disarm the vehicle. What I have done for now is placed the system in "Valet Mode" which is a temporary work-around, but when I called the Karr representative, he said he would need to make a mobile visit to reprogram it for $100. I'm sure it's something simple and will try to "unplug" it for a few minutes from 12 volt power and then reconnect it to see if it will "reboot".
    But if that doesn't work, does anyone here know how to reprogram a Karr system? I've been reading that it must be done after a power up, power down cycle within 3 seconds and then the driver's door lock-unlock buttons are then used to reprogram the features. Any help or links as to how to do this would be appreciated.
  2. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    The dealer can make it work, if under warranty KARR should come out for free, Somewhere I have a manual for the system.
    phoenixgreg likes this.
  3. phoenixgreg
    1,157
    294
    66
    Phoenix
    I finally was able to answer my own question so if anyone should need to disable, enable or modify Karr alarm programming - here's how:
    To enter "Valet Mode" (or disable the Karr alarm) - while Prius power is "On", press and hold the blue button below the blue LED for 5 seconds. You should see the blue LED become steady on and this disables the system completely. NOTE, the OEM alarm is defeated too.
    To exit "Valet Mode" to return to normal operation - within 3 seconds of the Prius power "On", press and hold the blue button below the blue LED until the LED goes out. Karr system is now operational.
    To program or reprogram features:
    Turn Prius on
    Press and release Karr button 3 times
    Short LED light with 1 short horn
    Before 3 seconds, turn Prius off
    Horn will give a short-long chirp
    Within 3 seconds, turn Prius back on (now in programming mode)
    Horn will give a long-short chirp
    Press Karr button one time per option (there are 4 options) the Karr LED will flash the number of times per option you are on. If you want to change an option, within 1/2 second, press the driver's side power lock/unlock button. If you wait 1/2 second or longer, the default program will be used.
    Option 1 (one flash): wait ½ second and horn should chirp once (auto-lock with ignition on)
    Option 2 (two flashes): wait ½ second and horn should chirp once (auto unlock with ignition off)
    Option 3 (three flashes): wait ½ second and horn should chirp twice (passive arming and lock without lock)
    Option 4 (four flashes): wait ½ second and horn should chirp twice (active arming)
    Turn Prius off to exit programming.
  4. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    Were is this Blue button, Im getting tired of my horn sounding when I dont press the unlock button.
  5. phoenixgreg
    1,157
    294
    66
    Phoenix
  6. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    Thank you, but the picture is really small. I search all over the place with no luck, this horn delay thing is going to drive me crazy.
  7. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    Rip that junk out of your car (n)
  8. phoenixgreg
    1,157
    294
    66
    Phoenix
    If you have a KARR alarm, the button should be mounted on the panel below the mirror adjustors near your left knee and above the parking brake. If you can't locate it, maybe you have a different aftermarket system or someone unscrewed the button assembly and tucked it behind that panel.
  9. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    When the car is armed you should see the blue led lighting up the drivers compartment.
  10. jorge luis covarrubias
    2000 Prius
    first, i want to apollogize because i don´t spèak english very well, i´ve just bought a toyota that has a karr alarm system, but i don´t have the alarm remote, my question is, can i programm any kind of remote on that system?, thanks.
  11. phoenixgreg
    1,157
    294
    66
    Phoenix
    The OEM Toyota smart key fob is the same remote to control the KARR system. What's different about the KARR is that when you arm it, you will get a chirp out of the horns and the parking lights flash once. To disarm, you will get 2 chirps from the horn and 2 flashes from the parking lights. Remember to press the unlock button twice if you want to unlock all doors.
  12. habin0421
    habin0421 New Member
    Los Angeles
    Thanks for the instructions. Do you know if it is possible to program the horn from sounding? The car originally already have the more pleasant chirp when locking and unlocking. I find it quite annoying with the sound of the horn on top of the chirp. My dogs would start to bark inside the house every time they hear it too. lol. It's that loud! Any help would be appreciated.
  13. phoenixgreg
    1,157
    294
    66
    Phoenix
    Hi - sorry, there doesn't appear to be a quiet mode with the KARR system.
  14. Adolfo
    Adolfo New Member
    Indio, Ca
    2015 Prius c
    So I too have recently had a Karr system installed, except when I'm disarming it the horn chirps 3 times, and then it starts to goes as if it was activated. Also, all my doors unlock even if I press the unlock button once. Any ideas?
  15. qdllc
    qdllc Senior Member
    1,377
    400
    I hear Michael Knight has experience in this area.
