anyone know the part number for 2007 mfd does not have bluetooth or navigation
Discussion in 'Gen 2 Prius Main Forum' started by cofrapp, Apr 20, 2022.
  1. cofrapp
    cofrapp Junior Member
    Staten Island ny
    need mfd touch screen buttons not working my car does not have bluetooth or navigation can't find the part number and don't want to purchase the wrong one
  2. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
    #2 alftoy, Apr 20, 2022
    cofrapp and ColoradoCrow like this.
  3. ydpplqbd
    ydpplqbd Active Member
    542
    250
    My 2006 Prius WITHOUT NAV or Bluetooth has 86110-47230.
    cofrapp likes this.
  4. dolj
    dolj Senior Member
    7,648
    3,858
    Wellington, New Zealand
    If you want to know with 100% certainty, the part number is on the back of your current MFD. Get a replacement unit with that part number and you can't go wrong.
    jerrymildred likes this.
  5. alftoy
    1,132
    509
    Bench Testing a Gen 2 MFD | PriusChat
  6. JahT
    JahT Member
    145
    75
    If you are interested in trying, I was able to replace the touchscreen on my MFD for about $20. When you go to remove the air vents to remove the MFD, be sure to pull them straight out toward the back of the car, there is a retainer on top and bottom of the curved vent assembly and if you did like I did and pull the bottom out and lift up it can crack the top (the part you see), so it is important to pull straight out and take your time. Youtube videos show them being ripped out, but that is just the force it takes to pop the retainer loose at top and bottom, you have to be careful with them since the plastic is so fragile. So work the top loose first if you can.
    Another likes this.
