Anyone know what that thing is?
Discussion in 'Gen 3 Prius Main Forum' started by ThatOddMan, Nov 28, 2020.
  1. ThatOddMan
    ThatOddMan Junior Member
    64
    25
    Alhambra, CA
    Found some photo. To install a tow hitch on my 2014 Prius Plugin, I need to remove it.
    Jesse Bechtold likes this.
  2. ASRDogman
    ASRDogman Senior Member
    8,018
    4,071
    It's hard to tell because it's so far away, but it looks like the tie down hook.
  3. hill
    9,013
    I was gona say . . .
    snatch hook spot
  4. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Isn't that the tow-truck connector, in case you need to be winched out of a ditch?
  5. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    I pulled the undercovers on my 14 PiP to measure for a curt hitch. I didn't see whatever that is - circled in the pic - on my PiP. And unless that pic is a mirror image of the actual view, my muffle was on the other side of the car.
    Is that your 14' PiP ? or just a pic you downloaded?
  6. Jesse Bechtold
    Jesse Bechtold New Member
    22
    Tucson, AZ
    Looks like a tow hook.
    iPhone ?
  7. ThatOddMan
    64
    25
    Alhambra, CA
    It's probably mirrored.
    The gas tank plastic cover on that picture should be on the driver's side.
    That circled area is on the driver side.
    vvillovv likes this.
  8. Deoc
    Deoc Member
    70
    39
    Pasco
    2014 Prius Plug-in
    No needed, the hitch you install can now be used instead of that hook, just dont get rid of it in case u need remove the hitch.
    ThatOddMan likes this.
