Anyone notice their speedometer is off?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by calbear, May 5, 2013.
  1. calbear
    calbear Member
    180
    30
    SF Bay Area
    Based on consistent readings from both a couple GPS units and all of those roadside speed radar signs, I think my PiP's speedometer is reading a couple MPH higher than I'm actually driving.
    Anyone else experience this? Can a dealer verify and adjust if necessary?
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  3. DLee
    DLee Junior Member
    81
    Speedometer reads 48 mph at 50 mph on my PIPa.
    Don1701 likes this.
  4. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    Yes it's off on all Prius. One solution is go with 205 tires when you re-tire. It corrects the speedometer and the slightly larger tires look better. Lots of threads on the topic with details on effects on mpg and odometer readings.
  5. bisco
    52,566
    so, if i'm traveling 55 (according to the speedo) in the right lane, whe i look in the rearview mirror, that's why the guy behind me looks like he's swearing?:p
  6. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Yep, when someone is riding my bumper, I make sure to do 2MPH more than what the speedo says, just to avoid road rage situations. It sucks that Toyota did this, but it's one of those annoyances we have to live with.
    F8L likes this.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I often do the same.
  8. El Dobro
    El Dobro A Member
    7,101
    3,279
    Not just the Prius, my VWs did the same thing. I add 1mph to what my GPS says I'm doing. :D
  9. Electric Charge
    545
    133
    Syracuse, NY
    Prius is off by 2mph (at least mine is). Makes you wonder how many road rage incidents were caused (and gas wasted by people angrily passing Prius vehicles) by Toyota just to save gas by fooling us via the speedometer ;)
  10. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Lets not forget the MPG computer that seems to almost always be 2-4 mpg optimistic....
    bvoyles and Hi Burrito! like this.
  11. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    when compared to my plug-in garmin gps my speedometer is spot on
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Since most car speedometers read high, I can only conclude that a lot of people driving Prii and being surprised at the speedometer optimism either have their first car or never paid attention to their speedometer accuracy before.
    mtbiker53, fuzzy1 and F8L like this.
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Part of the reason may also be the digital aspect. 2 mph is difficult to discern with analog gauges.
  14. bisco
    52,566
    good point.
  15. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    On my 2004 it varies. At street speeds it reads 1 mph high and 2 mph high at highway speeds.
    Interestingly, there is a button dance on the early 2nd generation to get to a maintenance screen where you can see internal GPS data with the same speed difference.
    iPad ? HD
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It's not just Toyota. Many manufacturers add this inaccuracy to their speedos.
  17. CharlesH
    2,798
    1,166
    Roseville, CA
    The speedometers reading high and the disabled screen functionality while the car is moving are both likely the result of demands from the rather conservative Toyota lawyers, rather than any technical reason. Apparently some car manufacturer(s) got sued by customers who got speeding tickets because they relied on a speedometer that read low.
  18. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Since my ICE doesn't pop on until I hit 65mph, that's a clue…
  19. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I obey the speedometer since that's the only legal measurement of speed. However, I try to keep the speedometer exactly at the PSL rather than driving with a lower reported speed to avoid "speeding", which is strictly what you should do.
    If someone's riding my bumper I follow the Maine Driver's Handbook:
  20. bisco
    52,566
    wow, 'drive slower' and 'reduce speed slowly', unheard of! those crazy maniacs.:p
    PLSPUSH likes this.
