Anyone Recommend Certain Fog Lights
Discussion in 'Prius c Accessories and Modifications' started by Jcarlos_nene, Oct 2, 2017.
  1. Jcarlos_nene
    Jcarlos_nene New Member
    United States
    Fog season is around the corner here in Central California I'm looking forward to installing fog lights on my Prius C 1, does anybody recommend any specific brand or lighting? I would appreciate any recommendations or suggestions and pictures if possible
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    The best type of foglight has a good cutoff that keeps the light low to prevent the light from reflecting off the fog back into your eyes. Typical foglights have very poor, or non existent cutoffs.
    You want projector foglights like these:
    Direct OEM Replacement Projector Fog Lamps For Toyota Scion Lexus IS GS CT LX RX | eBay
    Then for higher contrast, use warm color temperature bulbs like 2500K for better visibility and less glare.
    Here's a picture of my Camry with projector foglights and 2500K Nokya halogen bulbs against my garage door. You can see there's a good cutoff.
    Jcarlos_nene likes this.
  3. xliderider
    8,140
    3,277
    Honolulu, HI
    Keep in mind that unless you're car came with foglights, you're going to have to get a kit with the correct shrouds with foglight openings to replace the blanks that are on your vehicle. The kit will also provide a relay, dashboard switch, and a wiring harness.
    The foglights linked to above are just the foglights, nothing else is included.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    *Note: 2012 PC4 did not come with fog light cutoffs... :D
