Anyone remember how to draw these?
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Dec 30, 2018.
  1. Mendel Leisk
    42,361
    I did this a few years back:
    I did it in AutoCAD, but it works just fine with pencil, paper and a ruler. Only thing, I can't remember how I did it. My son turned me on to it; unfortunately he can't remember either. :rolleyes:
    Was trying to show the technique to one of the grand sons, but was stumped. :oops:
    I recall it's very easy: you start with a rectangle, draw an arbitrary diagonal line, then progressive lines, following some rules.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Not sure how to do the above but I had our 7 and 6 year olds at the local science museum yesterday and they had a weighted pendulum with a OEM on the end of an arm that would oscillate in a way that would make various patterns depending on how you moved the table as the pen was moving:).
    Kept them busy for a good bit of the morning(y).
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Zentangle? Not! lol I have no idea how to drow either of them.
    Zentangle
  4. Mendel Leisk
    42,361
    Yeah I'm trying to reverse-engineer it: colored-coded the outermost in each progression (magenta), then worked my way in a bit. Far as I can see, you do an initial lattice, 3, 4, or whatever sided polygons, filling the rectantular frame, then just start working your way in, with an arbitrary offset from each corner. That's why it works good on paper too, nothing exact, yet the outcome is kinda spectacular.
    Having colors kinda diminishes it, you see the pattern.
  5. Salamander_King
    11,024
    8,980
    New England
    Kinda like a kids toy, Spiral Draw?
  6. Mendel Leisk
    42,361
    Here's a hand drawn, first step laying out the boundaries, then fill in of one boundary.
  7. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Slow Sunday :whistle:?
    I bet you’ll be happy once you’re done:).
    Not a bad project to start before the new year(y).
  8. Mendel Leisk
    42,361
    Next time grand kids come, I'm ready.
    bisco and Raytheeagle like this.
  9. Mendel Leisk
    42,361
  10. padroo
    padroo Senior Member
    2,763
    2,253
    Looks complicated and I don't need to know.:)
    Raytheeagle and Mendel Leisk like this.
  11. Mendel Leisk
    42,361
    Somebody nearby fashioned a fence using similar principles, similar to the arbitrary first step. It's both devilishly clever and dead simple at the same time. I'll snap a pic next time we're walking the dog past that place, update here. (y)
  12. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Here’s some dead simple fencing that we did last year at this time:):
    8DD9F1C6-105A-4D11-9570-04860ED69B01.jpeg 0F689F9F-BA79-4DBF-955A-6EF03B120599.jpeg
    Nothing complex, just 103 feet of it:eek:.
    Only major challenge was the ground being rock and having to get the 60 pound jack hammer to dig the posts holes out:oops:.
    Turned out good though and the wife was happy with the result(y).
    srellim234, Mendel Leisk and ETC(SS) like this.
  13. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Looks nice.
    About 15 years ago we had to replace our back fence damaged in a big windstorm. We sank steel posts in concrete with flat steel crossbeams on both sides near the top, the middle and near the bottom. A 2x6 instead of a 2x4 laid down for additional lateral support on the top. We used self tapping screws to put the wooden slats on both sides. The end result is a fence that looks similar to yours on both sides to the delight of our neighbors and holds up like a brick wall in bad weather. You'd never know it has metal in it. If a wooden slat breaks for any reason it's very easy to replace it by just screwing a new one into the same place.
  14. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    I redesigned ours a bit as the previous designed ensured the continued support of a fencing company would occur every 10 years:cool:.
    We used pressure treated 4x4’s and dig down 20 inches where the previous fence wasn’t dug that low nor was pressure treated lumber used:(.
    We used metal angle brackets to lock the 2x4 supports to the 4x4’s rather than “toe nailing” the supports in as it’ll last longer;).
    Then used screws as well rather than nails for similar reasons:).
    As the slats fail, they are easily replaced and sourced;).
    Sounds like our minds think alike (y).
    srellim234 likes this.
  15. Mendel Leisk
    42,361
    Have to get you guys back on-topic:
  16. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Looks nice and definitely more custom :).
    The fence in the background was similar to the pattern we had before I modified it. The bottom rots out and then the slats flap in the breeze:cool:.
    How’d the drawing finish up last night:whistle:?
  17. Prodigyplace
    12,718
    11,850
    Central Virginia
    That was so last year! ;) :ROFLMAO:
    Mendel Leisk and Raytheeagle like this.
  18. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Or you could say he had all last year to work on it:p.
    He’s retired, he’s got nothin’ else going on(y).
    Mendel Leisk and Prodigyplace like this.
  19. Mendel Leisk
    42,361
    Post #9, second pic. Or you saw that, and it doesn't look very "finished"? :cry:
    Yeah we got ours redone a couple/three years back. In two stages, each with a gate. The first gate came with a nice diagonal brace, very sturdy. Second gate, same contractor but maybe different supplier, no brace on the gate and it promptly started sagging, bad. Contacted the guy, and he got REAL snippy. Won't be using him again. I took it off, squared it up and put in a brace myself. That was ATC Landscape.
    Their trademark is to put a treated landscape tie 4x4 along the bottom, keep it out of the dirt. To be fair they did a fair job apart from the gate, I guess they're erectors, carpenters not so much. And our backyard is a minefield of bamboo roots, not a lot of fun to dig.
    #19 Mendel Leisk, Jan 1, 2019
  20. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Sorry I was thinking it would have more to it, like the original post:oops:.
    Definitely more than I can do;).
    I definitely got the short end of the stick when it comes to creativity or artistry :sick:.
    But as a draftsman, I’m sure you’ve got a good archive of your talents(y).
