ANyone replaced the plastic rocker panels -prius v 2013
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by pvee, Jun 20, 2019.
  1. pvee
    pvee Junior Member
    2013 Prius v wagon
    I scraped the lower right side mostly the rocker panel but bottom of the doors a little.
    If I replace the rocker panel, can I reuse the hardware that holds them on.
    If I decide to patch and paint it, is there a better patch material for plastic, other than bondo like I would normally use on metal?
    Pete
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    The least expensive method is to just cover the black plastic substrate with brush on touch up paint, which enough can be has on ebay for $6 delivered. It would make the scratches less noticeable from a distance.
    Spending $300-500 on a replacement that needs to be refinished and painted for a 6 year old car would be false economy.
    Refinishing the rocker cover would cost at least $300 or so at a body shop.
  3. Mendel Leisk
    40,586
    Post some pictures?
    I like to pull stuff off, but never succeeded with the (probably similar) plastic rocker panels on ours. Looking at ours: it's a very "busy" design, many different fastener types, some of them failing. Also, there's a lot of odd little inset panels, prone to bending/deflecting.
    Not sure why it's so complex, seems like some little backwater of designers with too much time on their hands?
    Anyway, the lower down it is, and as long as it's not in danger of falling off or dragging, I wouldn't get too excited about it. Maybe a little satin-black Dupli-Color spray?
    For the door scrapes, get a touch-up brush in matching color (either Toyota OEM or something like Dupli-Color. I'm liking the latter now). If it's just the very bottom edges it's very easy to do a good job.
  4. pvee
    pvee Junior Member
    2013 Prius v wagon
    I am late posting this. Had heart issues and forgot about it.
    I patched, heated and reformed, and painted it with autozone touch up paint and it is not obvious to the casual observer. My wife.!
