Anyone successfully cleared permanent P0A80 DTC?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vallesj, Sep 8, 2024.
  1. vallesj
    vallesj Junior Member
    98
    Ok, I've spent an afternoon and a morning trying to follow procedure to clear this DTC. What I may doing wrong? I am following Chilton Library instructions:
    Confirmation driving pattern
    1. Connect techstream to DLC3
    2. Turn the power switch on (IG) and turn the Techstream on.
    3. Clear the DTCs (even if no DTCs are stored, perform the clear DTC procedure)
    4. Turn the power switch off
    5. Turn the power switch on (READY) and turn the techstream on. (I don't understand why you need it on at this step)
    6. Perform a "Universal trip".
    7. With the select lever in N, leave the vehicle until SOC drops to 30%
    8. Enter the the menus powertrain/hybrid control/trouble codes
    9. check that permanent DTCs are cleared (the P0A80 still shows up as permanent only)
    10. Notes, if permanent DTC is not cleared, repeat step 6 and 7.
    Definition of universal trip:
    1. Put the engine in inspection mode (this step requires you to start it with the engine off, and on IG, otherwise the mode cannot be enabled)
    2. idle the engine for 30 seconds or more
    3. Drive the vehicle at 25mph or more for a total of 5 minutes or more
    4. allow 10 minutes or more to elapse from the time the engine is started.
    For entering "inspection mode" (actually the dash screen shows Maintenance Mode)
    I had used VTCI cable and laptop with Techstream.
    I had used BT dong and Dr. Prius app. and OBDLink
    and the manual step with a device which is " on IG and within 60 seconds push 2x accelerator when in parking, push 2x accelerator when in neutral and push 2x accelerator when in parking. Then turn on (ready).
    I had done step 6 and 7 three times:
    • First 3 times cycle, by not turning off the engine when repeating step 6. Since I was already on "Maintenance mode" I considered no need to turn it off so that I can enable that mode again.
    • Second 3 times cycle, turning off the engine for step 6 (Universal trip graphs shows to start it off, then +30s iddle, +5min over 25mph, and wait for total 10 minutes since started the engine to switch it off.
    • Since there is a "hint" that the driving pattern can be performed consecutively in the same driving cycle, so before I switch it off, i left it on N until SOC reach lower than 30%
    I am not getting any new or pending DTC, so it is an indication that my HV battery is acceptable now after the repair, no more "check hybrid system". But that permanent P0A80 dtc is still there. Any clue what I am doing wrong or what step I am missing? May be I need to let the car cooldown before the next universal trip is performed? I noticed there is "number of warm-ups since DTCs cleared" so may be "3" or higher number.
  2. bkman
    bkman Junior Member
    64
    Greater Seattle Area, WA
    Permanent codes are usually clear themselves out after some time when the codition is no longer present. This happened when I forgot to hook up the hybrid battery after replacement.
    The coded cleared after a couple of days.
  3. ChapmanF
    19,056
    It depends on the code, because every code has its own confirmation driving pattern. If you don't go drive that pattern on purpose, then how long it takes depends on the way you normally drive and how long until you've randomly happened to hit all the same conditions as in the confirmation pattern.
    This is an unusual thread, though, as the OP really has looked up P0A80's confirmation pattern and gone through it on purpose, and hasn't seen the code go away. That's weird, and I'm kind of stumped myself.
  4. vallesj
    98
    There is other permanent codes there, maybe I need to clear them out before trying again the P0A80. Those are related to evap (p0441, p0455 and p0456 ), a loose or cracked hose, I don't know. They are not critical but is time I need to spend troubleshooting.
  5. ChapmanF
    19,056
    I drove around with a permanent P0102 for close to a year because, as it turned out, the confirmation pattern was missing a step in the old Repair Manual edition I was looking in. The member Elektroingenieur looked up the same procedure in the up-to-date manual online on TIS, and sure enough, there was a step that had been left out before.
    It was during the pandemic, and my greatly-curtailed driving had never quite hit all the conditions of that pattern for most of a year.
  6. PriusGold
    PriusGold New Member
    CA
    I am having the same problem until today, I have driven 1000miles but the permanent code is still there
  7. ollopa
    ollopa New Member
    Did this today with Dr. Prius and it took only about 15 minutes and only a few miles. Here's what I did:
    1. Used a scantool to clear all DTCs on the ECU and battery module, even though none were present.
    2. Overkill, but I disconnected the 12V battery for 5 minutes to make sure all stored codes were cleared.
    3. Reconnected 12V battery
    4. At this point, the permanent P0A80 code was still present, that's OK.
    5. Turn ignition on but do not start car, make sure dash does NOT say "Ready"
    6. Use Dr. Prius to enter maintenance mode and then start the car
    7. Confirm MAINTENANCE MODE on the display, engine will stay running.
    8. Let car idle for 30 seconds
    9. Go on a drive on a long country road or freeway, making sure speed stays above 25MPH for at least 5 minutes, total trip time needs to be at least 10 minutes.
    10. After a 10 minute long trip where the car was > 25MPH for at least 5 minutes, park somewhere and leave it in maintenance mode with the engine running.
    11. Shift the car to neutral with the AC on. This will start discharging the HV battery since the car cannot charge when the drivetrain is in neutral
    12. Use Dr. Prius to monitor the state of charge (SOC) while chilling in neutral. Discharge until SOC is below 30%. I stopped at 26%. Do not fall below 20% or else it will set a new code, but you must dishcarge to below 30%.
    13. Turn the car off.
    14. Start the car in normal mode, permanent code is now gone.
    I listed out every step to be as specific and detailed as possible but honestly this was very easy and took no time at all. The code cleared on the first try, I was actually surprised. The code did not clear until the very end, after dropping below 30% SOC and also turning off the car. I checked with Dr. Prius and with my Harbor Freight scantool, both which showed the permanent P0A80 before and both showed no codes afterwards.
    There is no need to drive hundreds or thousands of miles, just use a scantool and follow the procedure exactly. I used a stopwatch during the drive and paused it any time speed was below 25MPH to be absolutely certain of the times.
    CR94 and Brian1954 like this.
  8. JDrake
    JDrake Junior Member
    Chapel Hill, NC
    Thanks ollopa, this procedure worked for me (although I didn't bother disconnecting the 12V battery, and I put the car in Maintenance Mode with the manual, multi-step method).
    I was apprehensive about driving in Maintenance Mode, since you can damage the transaxle doing so, but I stuck to a smooth stretch of road and drove carefully.
    At the end of the "universal trip" (maintenance mode > 30 seconds idle > drive above 25 mph for at least five minutes -- doesn't have to be a consecutive five minutes > ensure entire trip lasts at least ten minutes), I stopped on a level patch of road and immediately put the car into neutral, then cranked the a/c with headlights on until Dr. Prius showed less than 30% SOC. Turned off car, started back up in regular driving state, and the P0A80 code was gone.
    Just be sure to not hit any potholes or rough stretches of road on your sedate ten minute drive.
