Anyone tried this Spare Kit from Modern Spare?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by CeruleanBlue, Apr 12, 2024.
  1. Mendel Leisk
    41,454
    I’d stick with procuring the more compact and lighter temp spare: you’re already dealing with makeshift, reducing interior free space, why make it even worse? A temp spare will keep you mobile.
    Yes I believe so. It’s sim to Camry?
    GcinFl likes this.
  2. Blackat
    Blackat Active Member
    459
    319
    Colorado
    2023 Prius
    Limited AWD-e
    Glad that works for you.
  3. reservoirblue
    reservoirblue Member
    95
    75
    Woodacre, CA
    2024 Prius Prime
    SE
  4. villageidiot2
    villageidiot2 Junior Member
    33
    2024 Prius
    Thank you! Really helpful! Do you think it would be possible to put a full spare underneath where the donut would normally
    go and secure it with straps through the cargo mat? I understand the floor won’t be level due to the height of the tire.
  5. Julio_E
    Julio_E Junior Member
    38
    Michigan
    2024 Prius Prime
    XSE Premium
    Thanks for this strapping info as the tire feels very secure now strapped in as recommended, with the Nite Ize 12' CamJam® Tie Down Strap (the 6' may have sufficed too) and thanks to all who shared their spare tire knowledge in buying my OEM or recommended spare tire and wheel. The Nite Ize strap is a dark gray so it may be hard to see in this picture (which is nice it kind of blends in). Being I just became a Prime owner, this is how I will carry a my spare. I still have a tire bag from Modern Spare in transit and once that arrives and I put my spare in that bag, I'll probably add some cardboard on the up side to cover up the "wheel hole", in the MS tire bag, so that I can lay things on top of that "flat cardboard surface" and not break the valve stem. But for now, just showing how I strapped it more the left and back to give me back more cargo area. Later on, I'll also see if I can rearrange my spider cargo thing in a better position.
  6. Julio_E
    38
    Michigan
    2024 Prius Prime
    XSE Premium
  7. NJW
    NJW New Member
    Philadelphia
    2024 Prius Prime
    XSE Premium
    Yes, the bolt pattern is now 5x114.3. I think I ran across someone who utilized the spare from a Prius V, which has the same bolt pattern as the current Gen5.
