anyone use a aftermarket rearview mirror?
Discussion in 'Gen 4 Prius Main Forum' started by galacticenergy, Aug 26, 2016.
  1. galacticenergy
    Los Angeles
    anyone use a aftermarket rearview mirror? like the ones you attach over the stock ones, and gives you a wider view or other effects
  2. UltraJetRefill
    150
    89
    Tucson, AZ
    Reviving this thread, since I'm in the market for one. o_O
  3. FuriousPrius
    FuriousPrius New Member
    2022 Prius
    Not a complete aftermarket mirror, but I always put those small convex spot lenses in the corner on each side. It works better than the blind spot monitoring imo (y)
  4. burrito
    burrito Member
    272
    105
    I had one in my old car (not a Prius), because I wanted to add an aftermarket back up camera. The mirror had a built-in screen which only came on when the camera was powered up (i.e., only in reverse). When not in reverse, the mirror looked like any other mirror. It was great, because it also auto tinted, which my stock mirror didn't do.
  5. Pulse07
    Pulse07 Member
    164
    93
    2020 Prius
    XLE AWD-e
    Anyone snapon one from amazon or knick knack store will do. I have one, took it off immediately because it get in the way of the garage opener and does not have auto dimming. But im sure you can find one and install one that does, but not worth the hassle me
  6. strike3
    strike3 Junior Member
    Placerville, CA
    2020 Prius
    L Eco
    I got one on Amazon and love it. I can see the blind spot in my right rear real well.
  7. peter
    peter Junior Member
    29
    gothenburg, sweden
    I use to turn the inside mirror away as much as possible as it shadows my forward right view.
    As i have two functional outer mirrors i do not need the internal one.
    ( the mirror is at level with my eyes, thus blocks a large area om my view )
Loading...
